Question about Blaupunkt Televison & Video
How do I use my Sky box remote to operate basic functions on my Blaupunkt tv?
Posted by Matthew. Doyle. on
Tom Chichester
    Top Expert:
  • Blaupunkt Master
  • 57,296 Answers
Unless your Sky Box remote control contains the necessary codes, it can't be done.
Posted on Sep 04, 2020
5 Related Answers
paul proctor
  • 4102 Answers
SOURCE: code for remote control
was the tv function working before or not as sometimes the controll will only work certain tv if it did work before is it a controll that can be programmed to work different appliances or not let me know and if you need the code for the remote i will try and get them for you post back and let me know the make and model of ctrl and make and model of the telly you want to programme the controll for ...............................
Posted on Nov 17, 2007
Anonymous
SOURCE: Sky remote codes
0065
Posted on Aug 27, 2008
Anonymous
SOURCE: Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Posted on Apr 23, 2009
Mick
  • 325 Answers
SOURCE: just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Posted on Sep 28, 2009
Anonymous
SOURCE: LiveWire - audio & visual - Universal Remote - code
dows anyone know ther contack number or website
Posted on Jul 31, 2010
Sky navigtor tv code tv samsung
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 4 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
  • If this works try the other TV functions.
  • If these work then the correct code has been selected.
  • It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Common Sky Remote Codes for your TV
Aiwa 0106
Akai 0098
Akura 0042
Alba 0043
Amstrad 0063
Baird 0117
Bang & Olufsen 0118
Bpl 0115
Beko 0125
Beon 0899
Brionvega 0147
Bush 0157
Crown 0225
Daewoo 0092
Decca 0244
Dual 0257
Ferguson 0293
Fidelity 0294
Finlandia 0296
Finlux 0297
Fisher 0154
Funai 0179
Genexxa 0330
Goldstar 0056
Goodmans 0335
Granada 0340
Grundig 0345
Harwood 0361
Hinari 0365
Hitachi 0145
Itt 0384
JVC 0053
Loewe 0442
Matsui 0477
Memorex 0037
Metz 0491
Minoka 0921
Mitsubishi 0150
Nei 0514
Nikkai 0528
Nokia 0536
Nordmende 0537
Orion 0549
Panasonic 0051
Philips 0081
Pioneer 0166
Protech 0595
Pye 0600
Roadstar 0625
Saba 0645
Saisho 0649
Salora 0651
Samsung 0060
Sanyo 0159
Schneider 0665
Seleco 0672
Sharp 0093
Siemens 0680
Sony 0000
Soundwave 0702
Tandy 0741
Tatung 0049
Techincs 0250
Telefunken 0757
Thomson 0771
Thorn 0772
Thorn-ferguson 0936
Toshiba 0156
Jul 06, 2011 | Televison & Video
Tip
Watch your SKY channels on a second TV with Magic Eye and remote
If you have Sky Multi-room this will feed a separate SKY signal from your LNB on your dish to a second SKY box if you have the basic this will not cost you anything you still need a card inserted in the front to make this work. I think it costs £5 extra for more channels.
So if you have SKY + you will have 3 coaxial cables coming out of your LNB. ( 2 for the SKY + and 1 for the Multiroom )
To ger the signal for free the easy way is to connect a coaxial cable from the RF2 output on the back of the SKY ot SKY+ box into another TV and use a SKY Magic Eye these cost about £5 and have a range of about 20 meters. You can use a coaxial splitter to feed two TV but you will loose more signal the more you connect.
You will need to turn this function on using the hidden menu to allow you to use the Sky Remote control then LED on the unit will show you that there is a signal.
Press <SERVICES> <4> <0> <1> <SELECT> and goto the RF2 output to turn the signal on you might find that this signal is already turned ON for you.
Note: If you are using a multiplex faceplate unit this signal will not work as it relies on continuity of the coaxial cable with a 12V DC signal being sent out of the back of the SKY Box.
For all setups changing you Box model or adding an extra box SKY must to this for you by having your phone line connected so they can reprogram your Smart Card.
on Jan 30, 2010 | Audio Players & Recorders
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Had working sky remote in bedroom, now no remote sky operation from upstairs, is there a secret installer code to switch this function on?
Have you got a magic eye in the bedroom,if so the little red light should be on,if it is not then you are not getting a signal from the main box.You need to check the 2nd rf output is switched on in the main box.
Nov 02, 2009 | Televison & Video
I just switch off the tv using the remote..now the remote is broken..how can i now switch on the tv?
Program your sky remote to give your TV basic functions like ON/OFF and volume HERE is the link on how to do it also there is a basic list here at sky user CODES or you can go to SKY website for a list of their codes, these will work on any version on the SKY remote 0742, 0205 or 0207
Alternatively there are many AIO remotes generally cheaper than the originals and have the added advantage of being able to put your DVD and VCR on it out there some websites even sell them pre-programmed for your TV check this LINK for Alternatives or Originals.
Hope this Helps
Oct 07, 2009 | Emerson EWF2703 27" TV
Trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Nov 24, 2008 | LG M1910A 19 in. LCD Television
Pin code for wharfedale tv
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Oct 18, 2008 | Televison & Video
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Televison & Video Logo
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
