SOURCE: bottom wash arm
there is a blockage but may not be obvious. arm turns only by water spraying out of the angled jets at the end of the arm. take arm off, run water thro the centre hole and this is udually enough to force the debris to the jets. clean out and check
SOURCE: Whirlpool dishwasher model gu1200 not working
I checked. There is no sheet of any kind inside or below the door of my Whirlpool dishwasher.
In any case, opening up the non-washing washer revealed that the filter behind the chopper assembly was clogged with food. I cleaned it off, put the thing back together again, and it was washing dishes again, until about three days later. I took it apart again and found food clogging the filter behind the chopper. I thought the chopper wasn't chopping, so I replaced it. It was around $16. About three days later it wasn't washing dishes again.
Further examination (dis-assembly of the sump motor and impeller) revealed that the end of the impeller (which is designed to engage the chopper) had broken off, thus the chopper no longer spins with the sump motor. The impeller costs about $20 and isn't too hard to replace, as long and you keep track of what you've dis-assembled and put it back together in reverse order.
On whirlpool dishwashers, the sump motor drives the impeller (it's connected via the threaded end of the motor shaft) and the impeller, in turn, drives the chopper. The chopper you can replace from inside the tub, without removing the dishwasher from its home or taking apart the sump assembly. But save your $16, as that probably isn't what is wrong... The impeller, being screwed onto the motor shaft, requires complete removal of the dishwasher so that you can completely remove the base assembly that holds the motor assembly.
If you have a GU-series whirlpool washer, the tech manual can be found here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
It has complete instructions for the replacement of every part.
SOURCE: frigidaire dishwasher
How old is your dishwasher? Mine is about 3 years old and just started the same problem but first made a noise for 1 month before.
SOURCE: I have a Whirlpool Quiet Wash dishwasher. I don't
yes.. keep going deeper you will most likely find what is blocking the chopper from turning.
SOURCE: whirlpool dishwasher leaks water around kick-
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
