Question about Hitachi Televison & Video
Set was dead before replacing board. Changing the board fixed power-up problem, but now picture is solarized... so is there a 'set-up' that needs to be done?
SOURCE: Main Power Board
The power supply board can be changed without any knowledge of repair but there are sometimes adjustments necessary if the picture is not normal. Many times it is fine. There a 4-5 voltage adjustments that would take some knowledge and a meter to accomplish. You need to hope it was diagnosed properly first. If it is completely dead the p.s is a good possibility. If it clicks on then back off almost immediately it is not likely the power supply.
Posted on Jun 23, 2008
SOURCE: Need to change timing belt on a 1981 chevy chevette/ set timing
bottom gear go straight up top gear sets about 2oclock thers a small hole in the gear too line up with a hole in the head use a small drill bit too check this!!!!
Posted on Apr 16, 2009
SOURCE: Power Problem with Zenith Z50PX2D
I had the same problem with same model TV a year back, they replaced some board (I was not there at home) as I had warranty and after a year same issue popped up again.. Can you please tell me what board replacement worked for you. I don't have warranty anymore.
Posted on Feb 15, 2010
SOURCE: I have an issue with
Here is the power supply: http://lcdpayless.com/productpage.php?productId=4780
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 07, 2010
SOURCE: Orion TV-32082, no picture
try fuse f404 on power board, feeds av and other screen circuits but not sound and tuner
Posted on Mar 13, 2011
