SOURCE: anti-lock, traction control, service soon,brake,
Anti-Lock and Trac Off lights are lit on my 1999 Alero, as well. They usually come on after about 5 minutes of driving, but are not always on when I start the car.
SOURCE: traction system
Hi there.Whats happening here is an abs sensor in the wheel has failed.In doing so it will turn off your traction control because your abs breaks and traction control work together .If maybe you have an auto zone near by they can scan your break system to find what abs sensor is causing the problem.I hope this clarified some for ya..Auto zone will scan the car for free so that won't cost you anything.You can drive the car you just wont have abs and you should get it fixed.Again I hoped I helped you and if you need further assistance I'll be here to help you..Have a great day..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: Anti-Lock brake light and traction off light came on
U have most likely damaged a wheel sensor ring, in order to ID the one you damaged u will need to have the ABS/TRACTION CONTROL system tested for trouble codes, this will lead to the right area for repair.
SOURCE: brakes
I don't know if the brakes dragging would cause the shaking or not but I will ask a question or two.
Does the car steer to the right or left when you apply the brakes? This would be caused by any leaking fluid or if one side is dragging heavily. This is because when the brakes heat up too much they begin to fade and loose there stopping power. If one side is dragging the car will pull to the other side when you apply the brakes.
You need to make shure that the brakes are clean and dry. Free from all grease or break fluid.
If a wheel is dragging the rotor will overheat and will cause "Blueing" of the rotors or they will look like they have small cracks in them.
Also did the shaking start imediatly after all the work or did it take a while?
SOURCE: the anti lock brake light and the traction
sound's like you just need to replace the brake pad's when they get to low the sensor will come on.
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off
intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction
Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator
steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery
Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while
Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes
Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error
codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake
Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady
on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse
connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005
Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control
Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
