Question about Locks & Locksmithing
Need to open diebold mod#17423A night drop safe, I have access to back of lock and have allen wrench tool to change combination
Posted by Guy B. Kobs on
5 Related Answers
ashburton
  • 417 Answers
SOURCE: Changing front brake pads
You shouldn't need to remove the calipers altogether just to replace the pads. You have remove the split pins or retaining springs on the old pads, then prize back the caliper pistons enough to remove them. Then push the pistons back some more enough to get the new pads in. Then reassemble and test.
Posted on Oct 23, 2008
Anonymous
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
Anonymous
SOURCE: how to change the combination of a Simplex pushbutton lock
Your screwed.
Posted on Mar 18, 2010
Anonymous
SOURCE: century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
Posted on May 25, 2010
SOURCE: How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Posted on Aug 09, 2010
How do I change the combination on a door key safe
Once it is already OPEN there is probably something side the safe and on the back side of lock access that will allow you to change the combination. I do not know the model number but this is standard practice so that one must know the current combination to reset it to a new one. Specifically how would be in your manual. The key would allow the over ride to access this recombination. I have a digital door lock that works similarly and you can either enter the numbers or use a key to unlock it unlike a analog safe it has both a master code (which allow the ability to create new codes or delete old codes) and an access code.
Feb 01, 2015 | Home Security
Change combination of S-50EB
Hi Ronald
To change the combination on the S-50EB you need first to open the safe. Once the safe is open, look at the thin inside edge of the door (nearest the hinges) and you should see a small reset button. Press the button and the amber light will come on. Once the amber light is on, you have 20 seconds to enter a new code. It makes sense to change the code with the door open, in case there is a problem.
Aug 01, 2012 | Safe International Digital Electronic Safe...
Hi, I have an older version of the Ilco unican corp pistol safe. IT is a simplex with the push buttons and a silver turner. I got it open, but don't know how to re program the code. Any help?
I found this instruction elsewhere on this site ( thanks to pctuneup191):
pctuneup191
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Feb 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to find instructions to change combination on Kaba L 1000 keyless lock.
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Feb 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Reset combination to keyless door lock
REMOVE THE KEY.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Change combination on a presto lock on a briefcase
Enter the correct code and open the case. Now push the button you use to open the case to the open position and hold it there, now push in the clamp and push the opener more and it will lock in place. Enter the new code and push the clamp part again to set it. Do to other side now.
Sep 15, 2009 | SK Hand Tool (87018F) 9pc. Fractional...
Harldline safe not opening
Sure blame the poor kid.
Think about it, what good would a safe be if by pressing a few keys the combination was changed?
As with any combination safe you need to clear the combination by turning one, two or three times in the opposite direction before entering the combination.
Now say your sorry to your kid.
Jul 24, 2009 | Safe International Digital Electronic Safe...
Century safe lock , not able to open the combination lock oper b
Apr 28, 2009 | Safe International Digital Electronic Safe...
Uplander 2006 rear turn signal getting access
You will need a star bit. It is similar to an allen wrench but shaped like a star and attaches to a socket wrench
Mar 20, 2009 | 2006 Chevrolet Uplander
Erased the code
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
The door must be open.
On models with the passage feature, make
sure the passage feature is disengaged: turn
knob or key should be in vertical
position (A) (see figure 14-1).
1. Insert the DF-59 control key (B) into the
combination change plug assembly (C)
and unscrew the cylinder by turning the
key counterclockwise. Remove the combination
change plug to gain access to
the combination change sleeve (see figure
14-1).
2. Turn the outside knob once clockwise
(all the way, until it stops) then release.
The latch should not retract (see figure
14-4).
3. Enter the existing combination. On new
installations, use the factory-set combination:
depress 2 and 4 simultaneously,
(release), then 3 (release). You should
feel a slight click as each button is
depressed.
4. Insert the spanner wrench as shown in
Figure 14-2 to engage the combination
change sleeve (A). Gently turn the
spanner wrench clockwise to the stop
position (a slight click should be felt),
then turn the spanner wrench counterclockwise
to the stop position (A) (see figure
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
the way until it stops, then release. The
latch should not retract (see figure 14-4).
6. Choose your new combination, write it
on page 26, then enter the new combination
— depress buttons care-fully
(a slight click should be felt as
Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
448 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
