Question about Bunn Coffee Makers & Espresso Machines
Electricity went off and forgot I had a Bunn Coffe maker. How does it affect my maker and what do I do? I heard it warming up after the power came back on. May I go ahead and make coffee as usual?
Posted by Nadine Brasier on
Brett Ahlin
    New Friend:
  • 6 Answers
It depends on the model you have but usually as long as you had water in the tank you can use as usual. If the power was off for a long time it will take up to 20 min to heat the water back up to temperature.
Posted on Oct 25, 2017
JonSnell Electronic
    Top Expert:
  • Bunn Master
  • 31,830 Answers
I would have thought so.
Posted on Oct 24, 2017
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: Bunn UPR warmer too hot
Try connecting two elements in series. See if this keeps it hot enough. (One switch controlling both burners.) See if another brand of burner will fit in the hole. Check to see if the wattage is lower.
Posted on Jul 07, 2008
Gord Thurston
  • 131 Answers
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Posted on Feb 10, 2009
Gord Thurston
  • 131 Answers
SOURCE: Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Posted on Feb 12, 2009
Anonymous
SOURCE: water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Posted on Jul 01, 2010
My bunn 10 coffe maker just died
not brew if no water coming in to filll the tank
Jul 11, 2014 | Bunn GRX-B
Why has my coffe maker stopped working
Does it have power? Try plugging it into another outlet that you know works.
Jul 11, 2014 | Bunn NHB Coffee Maker
My bunn coffe maker leaks water from the bottom I get only 8 cups not the 10 can it bbe repaired
If you will call Customer Service at 800-352-2866 with the model and date code we can further assist you.
Aug 14, 2010 | Bunn 10 Cup Home Coffee Brewer
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Poured water into a Bunn Vpr coffee maker, the coffe was cold. Why did this happen?
Possible the hi-limit turned off the heater, the thermostat is not working or the elements are damaged, or the inline thermal fuse is damaged.
Nov 20, 2009 | Bunn VPR Coffee Maker
Bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
52 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
