Televison & Video Logo
K
Kaye Thornton Posted on Oct 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to The Roberson Show have Dish Network but can I watch on iPad.will not accept application ?
Redacted
Level 2:
Habit-Forming:
  • Expert 91 Answers
  • Posted on Mar 27, 2020
Redacted
Expert
Level 2:
Habit-Forming:
Answers
91
Questions
0
Helped
35176
Points
223
You can with the Dish Anywhere app, download it from the App Store on your iPad. Sign in with your Dish account.
2 Related Answers
Anonymous
  • 185 Answers
  • Posted on Jan 06, 2011
SOURCE: We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Anonymous
  • 10406 Answers
  • Posted on Jul 30, 2011
SOURCE: G + MIMO Wireless Belkin Router - I cannot connect
Did you configure the router, to select:
1. SSID, the "name" of your network;
2. encryption-level. Hint: use 'WPA' or 'WPA2'.
3. password to your network.
If so, then enter the SSID/password on the iPad, to connect to your network.
How to install prophet bushiri channel on dstv
PROPHETIC CHANNEL SETTINGS on Your DECODER(DSTV)
Step: 1 Press menu Select "Advanced Options" Select "Dish Installation" Enter the pin "9949"
Select "Network Configuration" Select "Network 2 Setup" NB: Leave "Network 1 Setup (Home)" unchanged!! Set Signal Setup to "Enabled" by selecting it, and moving left or right Set Frequency to "11170" Set Symbol Rate to "26652 Set Polarization to "Vertical" Set FEC to "3/4? Select "Accept these settings"
Step: 2 Select "Network 2 Setup" Set Signal Setup to "Enabled" Set Frequency to "12682" Set Symbol Rate to "26657 Set Polarization to "Horizontal" Set FEC to "1/2? Select "Accept these settings"
Step: 3 Select "Network 3 Setup" Set Signal Setup to "Enabled" Set Frequency to "12722" Set Symbol Rate to "26657 Set Polarization to "Vertical" Set FEC to "1/2? Select "Accept these settings"
Step: 4 "Accept these settings" to go back to the "Dish Installation" menu then Select "Scan All Networks" Your decoder will go into scanning mode and might take a while to scan all networks. Do not interrupt the process even if it seams to take longer than you expected! Once completed, your picture will return as normal.
ENJOY WATCHING PROPHETIC CHANNEL.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
tip
How to connect your Apple iPad to the Internet
Connecting your Apple iPad to the internet is very simple. When you use a application that requires internet capabilities your iPad will do several things.
-The iPad will attempt to connect using the last Wi-Fi network you used that is available.
-If no network you previously used is available, the iPad will show a list of networks in range. You can then tap a network and if needed, enter a password to join the network. Any network with a locked Icon will require a password. These are secure networks.
-If no networks are available or if you don't choose one, the iPad will then connect over a cellular data network.
What is the difference between a cellular and Wi-Fi network? A Wi-Fi network is generally faster, but covers less of an area. Think of your home wireless network, or a wireless network at a library. It has limited range. A cellular network is generally slower but covers a larger area. Normally, if you are connected to a cellular network you will see a 3G icon or E icon at the top of your device. Also, you normally pay to use a cellular network.
To see all the Wi-Fi networks in range: From the Home screen, choose Settings > Wi-Fi. Tap a network to join it.
-G33k
tip
Top 7 iPad apps for watching video
Do you have some problem when watching videos on iPad? No worries, I've got a round top 7 best iPad apps for watching video, to help you watch your favorite televisions shows and movies to the utmost.
Netflix App - Top 1 video watching iPad apps
Netflix is probably the coolest iPad apps for watching videos and TV shows. The official Netflix app is free, and allows regular Netflix subscribers to manage their DVD and streaming queues. It allows you to stream the same shows and movies available online.
ABC App - Top 2 video watching iPad apps
The ABC player is the next best iPad apps for watching video. The app is easy to navigate either by show, or in the super-convenient calendar view and the video quality is crystal clear. We tried it out and this video watching iPad apps looks great and works well, at least over WiFi.
YouTube App - Top 3 video watching iPad apps
The iPad's built-in YouTube App for iPad is largely a scaled up and bigger-screen version of the iPhone app, and it works exactly like you would expect YouTube to work. Searching for videos is simple, and the interface is easy to use via touch screen.
Air Video App - Top 4 video watching iPad apps
Air Video enables you to stream video (converting it on-the-fly, if necessary) from your Mac or PC. The main limitation of this iPad apps is that it's free version only shows a few items(randomly selected) from each folder or playlist.
Hulu App - Top 5 video watching iPad apps
Hulu doesn't yet offer its own app, although one is rumored to be in the works for Hulu's long-rumored subscription service. Once this hits, we think the iPad will truly have access to most of the TV and movie content that people want to watch on a daily basis.
Ustream App - Top 6 video watching iPad apps
Ustream is another popular service for watching live videos on the iPad. The company plans to bring its Ustream Viewer app to the iPad, offering functionality similar to its existing iPhone application. Users will be able to browse live streams and then interact with them via Ustream's chat and social stream features.
Flixster App - Top 7 video watching iPad apps
Flixster shows you movie times at your local theaters and lets you buy tickets. It also shows ratings from Rotten Tomatoes and lets you play trailers for upcoming films. Sometimes it can be annoying, like when it pops up an advert for a film that you have to dismiss before you can use the app.
Note: iPad does not support HD video, if you want to watch HD video on your new iPad, you need to convert video to iPad with some video converter.
on Sep 28, 2010 • Computers & Internet
TV switch to live tive when wtaching recorded program
Hi there anil! My name is Kimberly and I form part of the Social Media Department with DISH, It is my pleasure to assist you. When watching an already recorded event and having a timer set up to record it should not interrupt your viewing of that DVR event. When this happened, did you get an error message on the screen? And has this happened again? Please reach me at: [email protected] with the details.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Can i watch tv on one tv while another person watch a recorded show at the same time?
Hey russ fenton,
On the 625 receiver; the Dual mode allows you to record in one room and watch live TV in the other or watch live in one room and a recording in the other.
Tommy Faust
DISH Network
My dish network DVR says it is recording a show in the guide but doesn't show up in my list of recordings. I have two tvs. I watch on tv 2. Why can't I watch my programs. I was told what ever...
Hi my nameis Mike Houston of DISH Network and I see you can not watch recordings on TV2and you can't watch and record at the same time. The first thing you will wantto do is make sure the receiver is in Dual mode, I will send a link to helpwith these steps and if the problem still persist please e-mail me at [email protected]. http://www.dishnetwork.com/SupportSection/same-video-2-tvs
For the past couple of days, every show our DVR has recorded freezes a couple of minutes into playing it and the DVR reboots itself. This always occurs at the exact same time on that show. We don't have...
Hi, Mary with Dish Network Customer Service. Since the DVR is the only thing having the freezing issue, it sounds like it maybe a hard drive issue. I would recommend resetting the receiver. Unplug it from the power supply for 10 seconds and then let the receiver reboot itself. If you are still having this issue, I would recommend calling Dish Network and we will need to replace the receiver. Hard Drive issues do not resolve themselves and only get worse over time. Please let me know if I can be of further assistance.
Can I record a tv show while watching another on the same tv?
Hello! Dan Busa with DISH Network here. You absolutely can but only if the other tv is doing the recording.
Dish DVR problems
if the show that you are recording is also skipping on live tv, then it could be 2 things. it could either be a broadcasting issue (which the broadcasting center at dish network would have to correct on their end) or 2. it could be that your dish needs realigned. also if you purchased the dish dvr through dish network their models are quite often refurbished where they fix old models and send them back out. (most satellite companies do this) contact dish network and let them know you are having a problem, they may replace your dvr and if you have a protection plan they will often replace it for free.
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
