Question about iLO Televison & Video
WELL???? PDP4210EA hooking up to it?
WANY TO HOOK PLAYSTAION ,ROKU BOX TO A ilo pdp4210ea TV ILO
Posted by Harriette Binder on
Remotes.com Customer Care
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 24 Answers
I was able to find a service manual online which lists the inputs for that TV as the following:
  • RF connector (cable/antenna)
  • Composite (yellow video, red/white audio)
  • S-Video
  • Component (red/green/blue video, red/white audio)
  • D-Sub (analog PC connector)
  • DVI (digital PC connector)
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
Posted on Oct 24, 2017
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: ilo power cord
You may want to contact Funai. They are the company that makes the Ilo brand. Their parts department may be able to find the cable you need and order it for you. 800-242-7158 [email protected]
Posted on May 12, 2007
Anonymous
  • 4 Answers
SOURCE: ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Posted on Jan 12, 2008
Anonymous
  • 124 Answers
SOURCE: need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Posted on Nov 12, 2008
Anonymous
SOURCE: viore model# pdp4210ea
Hey I have the same problem and just had mine looked at by a TV repair and it was diagnosed as the main board which was quoted at $1100.00! good luck
Posted on Mar 23, 2009
Anonymous
  • 5 Answers
SOURCE: TV remote codes
press menu and go to settings. select remote, code search and follow the on screen instructions it may take a few minutes to locate the correct code but it is in there.
the installer told us that the remote could not be programed to our ILO tv, he was wrong I made it happen without any trouble.
Posted on May 03, 2009
How do I hook up my digital cable to my ilo flat screen TV with out a box
It won't work because the tuner from your ilo TV will not be able to decode the digital signal from the cable company even if your TV has a digital tuner. The digital tuner on your TV will only decode over the air signals.
You will still need the digital cable box from the cable company.
Aug 03, 2015 | iLO Televison & Video
My ilo hdtv doesn't have a cable hook up
Going to have to connect (no coax fitting means it is a monitor with no tuner) via one of the rear audio/video inputs with a box that has those outputs on it.
HD is almost always connected in this way.
May 02, 2012 | iLO IWT3206 TV
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
Hook up surround sound
if you are using a dirtv or other cable box, you should plug in the audio to your stereo from the cable box itself.
May 26, 2008 | iLO 3200 32 in. LCD Television
Ilo 32 in television
I need to hook up remote for Direct TV and Ilo is not listed as a choice what do I use?
32 ilo lcd
most boxes have component out or HDMI connection use either one and cable box or satelite came with instruccion on how to connect it ..
Mar 30, 2008 | iLO LCT32HA36 Television
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Televison & Video Logo
69 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
