SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
SOURCE: Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
SOURCE: all incoming calls go straight to voice mail
Just go to call settings and then call divert. check settings. Maybe all calls are diverted to voice mails. Cancell all diverts. Then you are done.
SOURCE: Motorola I415
press your menu button, that looks like papers with lines. under that there is a profiles section. select that and you should see a list that says standard, silent, etc. Select standard or one of the other profiles.
SOURCE: Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
Hope this helps someone?
vandata1
