Vacuums Logo
Kennth Harshaw Posted on Oct 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stuck zipper bag
Can change the bag because the zipper is stuck
George Scott
Level 3:
Master:
  • Master 789 Answers
  • Posted on Oct 24, 2017
George Scott
Master
Level 3:
Master:
Answers
789
Questions
Helped
228348
Points
2507
Magnifier/lite/needle/ time /start working just any zipper
2 Related Answers
Anonymous
  • 126 Answers
  • Posted on Jan 27, 2008
SOURCE: Vaccum Bag
Slide the plastic piece off the cloth bag and open the top. Looking down into the cloth bag, you will see the old bag. It is secured to the machine near the top. You will find the cardboard collar about a third of the way down. Remove it carefull. Now, stand BEHIND the machine and put your knee against the back of the handle and taking the new bag, open the hole in the cardboard collar and insert the bag into the cloth bag and put the cardboard collar onto the handle fitting. It helps to put the lower part of the hole on first and then press the top of the collar onto the handle fitting. The idea of standing behind with your knee against the handle is so that as you attach the bag, you will be pushing against your knee which will steady the machine and allow you to use the required force to complete the action. Once completed, fold the top of the paper bag down, so that when you replace the top slider, the paper bag is NOT clamped between the cloth bag and the slider.
fixitcr63
Corky's Craft Shop
  • 210 Answers
  • Posted on Apr 10, 2015
SOURCE: I have two G3 Kirby i changed the bag assembly because I got the zipper stuck on the one and the bag was full and needed changing not it won't start
Mary, It sounds like you didn't get the bag on properly. When putting it on the neck you must turn it until the small lever on the side of the machine is depressed. This is a safety switch so that the unit cannot be run without a bag. Once it is properly installed it should run for you.
Kenmore vacuum hood stuck open after changing bag. Model 116.27514.
Line up the locating pins and make sure bag isnt sticking out anywhere around where the cover seals and close to up.
Jan 18, 2019 • Vacuums
How do I get my zipper unstuck on my Kirby Vacuum 100
You might try some lubricant like Vaseline ,sewing machine oil ,DW40 or even cooking oil and after you have soaked the zipper and along the track both ways use a pair of pliers or similar to grasp the zipper and move it in the direction that should open the zipper ! this might be difficult at the start so dont use excessive force in fact a push and pull method often works best ( or pull one way and then the other )because a realignment of the zippers teeth is often what is required and forcing the zipper can often tear them away from the material and a zipper replacement would then be necessary, other causes of stuck zippers are things like stray cotton or material caught up in the teeth and zipper ! If you do end up having to force the zipper maybe replace the zipper with a strong Velcro or a more robust zipper with larger teeth .
2answers
Oreck bag zipper is stuck and can't open bag
No fix. You can order a replacement bag from your local oreck dealer.
1helpful
2answers
Having a terrible time keeping the bag attached during use. I am tired of cleaning the inside of the cloth zippered bag. I am using the correct Oreck vaccum bags, and using the metal clip that holds the...
I would Recommend getting a docking system. its $20 and takes place of the metal clip and ensures that the paper bag and outer bag both stay in place and to ensure no leakage.
I have the electrolux guardian-My full bag light indicater is coming on even with a new bag. It gets worst-the machine will cut off when I insert the hose or put my hand over the hole where the hose goes....
Check your hose you have something stuck in the hose...stretch it out straight and run something through it to push out whatever is stuck in there...
heatman101
2answers
I broke the zipper on the cloth bag on my kirby gen. 3 can i replace this myself
Yes.
To order Kirby vacuum bags, replacement parts, or cleaning products, please visit your local independent Kirby Distributor, or call:”
1-800-437-7170 United States and Canada
1helpful
Vaccum Bag
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
