Question about La Crosse Measuring Tools & Sensors
How do I set the outdoor temperature on la crosse technology ws-9160u-it
Posted by Linda Davis on
Steve Pack
  • La Crosse Master
  • 4,331 Answers
How do I set the outdoor temperature on la crosse  - 3agvjl5x2spn2517xoxc00wkeckttcetgtaid3hlilbfrptqhwzntgv9mzaxi+fswcangpduny7xrqwqbalgiisoyxk+tzbddqwqf9olnhhn4x90flaqaxoqmrn93m6scgsjks0dbla6hszkcyaaaaggqqgxmolaaagfmnvbyaaacii1hv9v8dvgk7olr6+ayaaaaasuvork5cyiia
Posted on Oct 26, 2017
5 Related Answers
Anonymous
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
Posted on Sep 22, 2008
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: Display is fading
Check the batteries first before trying to tinker with the display. Also check for accumulation of fungus, if any, which can also cause the display to fade..............sodeep
Posted on Jul 24, 2009
homedesigner
Mark Tidwell
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
john milligan
  • 514 Answers
SOURCE: need instructions for model #2316 La Cross
per the manual at http://www.lacrossetechnology.com/2316/manual.pdf on page 2 section 5 the unit sets its self to the world time radio signal from boulder colorodo on its own after it get the security code from the sensor pack.
Posted on Nov 18, 2010
SOURCE: La Crosse technology
What light?
Posted on Dec 02, 2016
My outdoor temp is slowing almost 10 degrees warmer than actual temp outside. What is problem.
You are using a wireless system that transmits signals between the outdoor sensor and the indoor receiver. They are not a perfect match. You cannot make adjustments, thus if your lucky, the factory matched up the devices prior to the sale. You may contact Lacrosse for a replacement outdoor temperature device.
Jan 11, 2018 | La Crosse Measuring Tools & Sensors
Changed batteries,now weatherstation does not receive outdoor imformation
La Crosse is very specific about what you should do and how you should do it for a battery replacement.
Begin by removing all batteries, both outdoor and indoor. Install new batteries in the outdoor unit. Allow the time it takes to get from the outside to the inside for the outside unit to initialize and begin sending data. Install batteries in the indoor unit and observe outdoor temperature. You should see indoor temperature as well. Finally, set the time. This last can be tricky as it seems difficult to set an exact time. I have two different La Crosse receivers connected to one transmitter and the one in front of me now is indicating 70 deg F indoors and 80 deg F outdoors.
Sep 11, 2016 | La Crosse Technology The Weather Channel...
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
How do I get a new outside temperature sensor?
You may have to order a replacement sensor directly from La Crosse.
Apr 29, 2015 | La Crosse Technology Lacrosse Technology...
My outdoor temperature shows three lines I have change the battier as manual said, but it didn't help? Do you sell replacements?
Fixya does not sell anything. The replacement batteries in the outdoor unit could be defective or installed incorrectly. The battery replacement procedure in the instructions must be followed exactly, i.e., batteries replaced in the outdoor unit then allowing time for the outdoor unit to begin sending data before installing batteries in the indoor unit to get an external temperature readout.
Oct 09, 2014 | La Crosse Technology Ws-8418u-it Atomic...
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. [email protected]
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
Measuring Tools & Sensors Logo
1,000 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
