There are a lot of accessories available for free motion quilting. However, in reality, FMQ can be done with a darning foot (usually included with your machine). Of course, you can opt to purchase a multitude of FMQ presser feet for your machine, ie open darning foot, clear foot, hopping foot...plus many quilting rulers. The only other change is to drop the feed dogs. From there, it's just a lot of practice, practice, practice. It helps to practice drawing FMQ designs on something like a blackboard or whiteboard that can be erased and used multiple times. The idea is to get your movement smooth and consistent--muscle memory--like you used to do when learning how to write in grade school. It may also be helpful to have some gloves that will grip the fabric since your skin will become dry from constant contact with the fabric and begin to slip. There are special "quilting" gloves for $$ or you can try some cheap rubber gloves from the dollar store or rubber garden gloves.
How to Practice FMQ
How to Set Up For FMQ Video Tutorial
https://www.quiltingboard.com/main-f1/fmq-question-t283638.html
Or, you can do straight line stitching with a walking foot, which is easier than FMQ. But you would need to purchase a walking foot for your machine.
Just search for free motion quilting. There are tons of web sites, videos, and classes.
SOURCE: Singer 7430
I have a new machine. This is the second the first had the same problem so I exchanged it. It worked fine on 1 project on both machines the next the time it did the following. When sewing stich #8 which is a zig-zag stitch with a straight line on one side, I get the #8 stitch on one the bottom side and the #13 stitch on the top side. I have read the manual, also re-wound the bobbin twice re-threaded the machine twice and changed the needle none of these worked. Do you have any suggestions.
SOURCE: I need a walking foot for a Necchi Model 4795 for Quilting.
http://www.sew4less.com/product/2034/Low_ShankEven_Feed_and_Walking_Foot_and_Quilting_Foot_10449
SOURCE: I have a singer 6202 sewing machine and I need to
You have to unscrew the presser foot, then attach the WF, using the same screw.
Make sure the lever on the WF rests on top of the needle bar clamp.
Some WF have a two prong lever and this fits around the needle clamp like a lobster claw.
SOURCE: How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
