Question about The Audio Players & Recorders
My Blackweb bluetooth headphones are not in stereo any more after 5 uses. The right ear is not responding or its intermitten.
Posted by Jeanne Rogers on
NOEL
    Top Expert:
  • The Master
  • 8,555 Answers
Not sure but it sounds like a lose wire in headphones or a faulty jack plug.
Posted on Oct 23, 2017
5 Related Answers
Michial Gueffroy
  • 1140 Answers
SOURCE: no sound from headphone
Worse case scenario is that your left speaker is gone but usually what happens is a break in the cable someplace.Are you using the 1/8" plug or are you using them with the 1/4" adapter. The 1/4" adapter might be worn out but is easily purchased and replaced.The cabling from the plug runs into the left can and from there splits into left and right speakers. There will be a wire that follows the head band under the cushion from left to right. With these headphones there is a swivel above the can and the problem might be in there. Half the problem is getting at the wiring to test it. Usually the plate that the speakers are mounted on is screwed to the back cup and the screws can be reached by removing the earpad. You will need a volt ohm meter to test the wiring. You can also test the speakers with it. Unfortunately most plugs on headphones are molded onto the cable so you will have to start by testing from the plug to the left can. Inside the left can will be a junction point where the main cable feeds the right speaker. Test up to there for right and left and if the connections are good then test the speaker. Hope this helps.
Posted on May 14, 2009
Anonymous
  • 6 Answers
SOURCE: left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
Posted on May 19, 2009
Anonymous
SOURCE: Headphones are only working in one ear.
This is a common problem. All stereo adapters will only play in the right ear. What you should do is send back the headset adapter and get a stereo headset that plugs directly into the 2.5mm jack, without going through an adapter. That should solve the problem.
Posted on Aug 04, 2009
Anonymous
  • 11 Answers
SOURCE: Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Posted on Aug 27, 2009
Anonymous
SOURCE: Headphones Compatible with LG POP.????
I dont no about the headphones but i do no where to get a case from
http://www.amazon.co.uk/lg-pop-case/s?ie=UTF8&rh=i%3Aaps%2Ck%3Alg%20pop%20case&page=1
Posted on Nov 23, 2010
3helpful
2answers
Red light wont turn off on auvio headset
While your headphones are charging press and hold the call button and volume up button and your problem is solved.
2answers
I cant find headphones that fit in my phone?
Try to contact the vendor for genuine headphones, is your cell phone have bluetooth connection? if any just use bluetooth that have universal connector. so you could use any headphones you want.. hopefully it works..
3answers
Do you have different kinds of earbuds for the Backbeat 906 bluetooth headphones? The molds I have are ok and would like to try to find the marshmallow buds.
  • Universal Bluetooth headset for Apple iPhone 6/5s/5c/5, iPhone 4s/4, Samsung Galaxy S5/S4/S3, PC Laptop, and other bluetooth device;
  • Deep Sleep mode extends battery life;
  • Noise-cancelling microphone reduces background noise;
  • Fits comfortably in either ear with a super soft gel ear tip;
  • Super easy and fast paring with your smartphone or other Bluetooth device.
Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
1helpful
2answers
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
2answers
Sound in left headphone only sometimes works
you can warranty them on there website. they will probably send you a new pair.
3answers
I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
1helpful
2answers
Motorola stereo bluethooth headphones
The G1 Doesnt support Bluetooth A2DP yet, meaning it cant stream music via Bluetooth. Yet !
Oct 27, 2008 • HTC G1
Music problem
i dont know how to download music on the motorola s9
can u help me please
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
GLESGA BOY
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
