SOURCE: Why does the VCR ejects my tape?
The VHS PlayPak adaptor uses 1 AA battery. When you place your VHS-C tape into the adaptor and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink-wrap has been removed from the battery.
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the
right side of the mechanism) and turn its shaft with your fingers until
you have run the tape back out. Now plug it back in and try it
again with a scarificial tape. If it continues to fail, replace
all the rubber belts in the mechanism.
Hope ya fix it!
SOURCE: Stuck VHS Tape in Samsung TV/VCR Combo
HI,
Please unplug all the cords of your TV for 4 hours and allow it to reset.After 4 hours plug the cords back in and now try removing the tape.
Let me know the result
SOURCE: Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
