SOURCE: Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: how to replace the roller on a belt sander
you can order one from this website
http://www.ereplacementparts.com/rubber-sleeve-p-10894.html
SOURCE: I just need to know how to remove and replace the drive pulley on the DeWalt 432 belt sander.
You need a Screwdriver (Phillips) and a pair of Pliers... Get the Pulley FIRST, Take the screws out and split the case, you will see the Pulley. Replace the Pulley and reassemble
Testimonial: "The pulley will be here in a couple of days and then I will try it. Thanks! "
