Question about Nortel Lands Phones
I have a nortel meridian m 7310. i have set a restriction filter and applied it to several sets but the restriction only worked for two of them, the others work normally with no restriction.
I used feature **266344, general admin, capabilities set abilities show set and the applied the filter for each set. it shows that all the sets have the filter. what else could i try?
5 Related Answers
Anonymous
SOURCE: Changing the time on a Nortel networks phone
Feature **time (type out time on the dialpad.)
Posted on Apr 17, 2008
Anonymous
SOURCE: need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Posted on Mar 10, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Mar 25, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: Nortel T7316E need to reset all the password
How to Change a Mailbox Password 1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Posted on Apr 24, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
Posted on Nov 04, 2009
All of a sudden the line lights on our nortel switch Meridian M7310 phones started blinking and the lines are dead. Any ideas?
If you only have one line,why not just lose the Nortel system? You can reuse the wiring from the phone sets to the contoller as regular inside wire,and just plug in regular phones(and maybe put the Nortel phones and controller on EBay and make a few bucks off it!)
Oct 26, 2012 | NorStar Meridian M7310 Phone
Tip
Nortel Meridian 1 Manual Download
Download Nortel Meridian 1 Administration Manual
Have you misplaced your Nortel Meridian 1 Administration Manual?
Would you like a digital, searchable, pdf version of the Nortel Meridian 1 Administration Guide?
Follow this link
(& click FREE) to download a pdf version of the Nortel Meridian 1 Administration manual.
I hope that helps.
____________________________________
Nortel M7324 Manual Download
on May 04, 2010 | Lands Phones
Nortel 7310
Do you mean Voice Mail?
Have your office manager or on site admin change it or call your local vendor for admin training or cheat sheet.
You can also get required info from any Norstar Setup and Operation Guide
Sep 18, 2012 | NorStar Meridian M7310 Phone
Installed this NT9K08AD03 where a NT8B30AD03 was and the new phone does not work. Meridian Compact ICS 2.0
The M2008 set (NT9K08AD03) doesn't work on a CICS system. It works with the Meridian PBX systems. The type of sets that work with a Compact ICS system are M 7100, 7208, 7310, 7324 and T 7100, 7208, 7316, 7316e as well as some of thier cordless sets.
Oct 01, 2010 | NorStar M2008 PBX Phone (nt9k08ad03)
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Sep 10, 2010 | Nortel Meridian M7208 Corded Phone
Getting the M7208 to work
Nortel M7000 series are proprietary sets which require a nortel MICS, CICS, or an older 8x24, 6x16, or 3x08 in order to work. If you have the system, it maybe that the jack isn't activated with a system port.
Nov 24, 2009 | Nortel Meridian M7208 Corded Phone
I need different ringtones on my Nortel 7310
you should already, intrnal is double ring and external is long single ring. you can set sounds from the softkeys below display.
Nov 12, 2009 | Lands Phones
Mar 24, 2009 | NorStar Lands Phones
Every button including feature Meridian 7310 calls to an internal
Sounds like a stuck button.
Do what I call the rake... swipe at the keypad over and over, look to see if there is any button lower or depressed on the keypad or buttons.
Someone may have spilled something on it (cola, coffee), and the set may require to be taken apart if there is a stuck button.
Mar 09, 2009 | NorStar Meridian M7310 Phone
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
Lands Phones Logo
37 people viewed this question
Top Nortel Lands Phones Experts
Marvin
Marvin
Rich Barnett
Level 1 Expert
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
