Question about Locks & Locksmithing
My new safe will not lock. the knob turns without keying the code
Anonymous
  • 9 Answers
SOURCE: my sentry safe
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
Posted on Feb 08, 2008
I can't get my wall safe to open.
maybe you have to change the battery for the keys/ or just get a lock smith
Apr 11, 2018 | Building Materials
Have a safewell electronic system safe ex2007126498 want to open it lost key and forgot the password
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the codeicon1.png as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell [email protected]
Apr 22, 2014 | Computers & Internet
Change code number to a new number on safe e.d.safe s25ebf
electronic keypad -159B. (These numbers are preset. You should change the code as soon
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
knob so you can turn it and retract the live action locking bolts.
Aug 04, 2011 | Office Equipment & Supplies
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
won't work.
ELECTRONIC SAFES
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
Have a SURESAFE brand safe at work which have no instructions
Hi there all I have a SURESAFE electronic security safe MODEL-OWSAFE30ES
(1) To set your own code first on safe
(2) locate the red reset button on the hinge end of the door.
(3) Press the red button, which will illuminate the yellow light on the keypad.
(4) Now key in your new code (3 to 8 digits) and press A or B to end. Note you have 30 second to complete this step.
(5) Test your new code whilst the door is open. Safe will beep twice to confirm code has been entered correctly, and knob can be turned clockwise.
(6) Repeat process any time you wish to change your code.,
Hope this help
regards
rick
Dec 30, 2009 | Safe International Digital Electronic Safe...
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
electronic keypad –159B. (These numbers are preset. You should change the code as soon
Good luck
Sep 14, 2009 | Locks & Locksmithing
SD102 missing the key
Hi.
Yes, you need the key to open it.
Your code is 4 numbers (one or two digits each).
First turn the knob several times counter clockwise To "reset for starting)
Turn the knob clockwise. Stop when you hit the first number the fourth time. Then counterclockwise, and stop when hitting the second number the third time. Counterclockwise again until you hit the third number the second time. Counterclockwise, and stop when hitting the fourth number the first time.
Now you need the key. The safe opens when you turn the key clockwise. I don't know where to order a new key, but I suppose the manufacturer can help. Your key number should be engraved ON the lock. Mine has four digits lock/ key- number.
I have not been able to find the manufacturers web page...
I wish you luck!
Stein/ Norway
Jul 08, 2009 | Safe International Digital Electronic Safe...
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
170 people viewed this question
Top Locks & Locksmithing Experts
john h
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
