The rest of the buttons on the touch pad work, but I cannot adjust the temperature since the numeric buttons do not respond.
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
SOURCE: GE JKP27WP1 Built-In Double oven
Try gaining access to the touch pad and, try to free up the start button. if this is unsuccessful, replace the touch pad.
SOURCE: no display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer
SOURCE: GE model JVM2070SK02 touch pad not working
Most people, and GE will tell you these are not repairable and you must replace the whole unit for $300 - 500. I can fix them. If you are interested, let me know. [email protected] I can only fix the touchpad not working and it must not be physically damaged. You must be able to take out the control panel and send it to me. It is easy (3 screws and electrical connectors).
To Adjust
the Thermostat
To Adjust
the Thermostat
