SOURCE: 6 months old. Now no water will fill drum! Works as normal but no water!
I'll bet you have those new "flood safe" fill hoses. Get rid of them. Install normal, ordinary fill hoses and all will be well in the world.
SOURCE: Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
SOURCE: Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
SOURCE: my spa won't blow bubbles but it will heat up. It
You opened the air valve??? Usually a round thingy on the edge of the tub.
I cant imagine how this would not work if it were open ... it works on the same idea as a carb on any gas engine. If the hole is open, the water stream will **** in air.
SOURCE: replaced heater failed within 2 months
If your filter is plugged causes the heater to work harder(overheat). Rus
