1999 BMW 328 Series Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Resetting brake warning light
I have a 1997 BMW 528i. The pads and rotors were just replaced along with both brake sensors. Do you have to reset the lights somehow or will it do it on its own? How do you reset the brake light that is illuminated in the dash?
Anonymous
Level 2:
Sniper:
  • Expert 113 Answers
  • Posted on Jul 29, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
113
Questions
0
Helped
88247
Points
361
Hi , if you turn the ignition on so that all the dash lights are on , do not start the engine and leave on for aprox 45 seconds the brake pad warning lights should go out, regards mark
  • Tim french
    Tim french Dec 29, 2013
    Thanks worked the first try.
Brake pad wear sensor
sometimes you need to have a garage reset it with a scanner
3helpful
A light in the dashboard turns on today and I have no idea what is the symbol for? is like a circle with 3 rectangles in line on each side this is a BMW 318i, 1996
This is the brake wear indicator. When the brake pads get too thin, this sensor, which is mounted in the brake pad backing on the front left wheel and the rear right wheel, touches the rotor and wears through, grounding out the contacts and illuminating the light.
Once the light is lit, you will need to buy a new sensor as well as new brake pads. The sensor is not expensive.
First step is to examine the brake pads and determine if you need front pads or rear pads or both. Don't be surprised if you need new rotors as well as pads. Check for a significant lip at the outer edge of the rotor. If the pads have worn in the sides of the rotor more than about 1/16", you are due for rotors.
You cannot go wrong with BMW branded pads. They are safe and work great, but they are really dirty. If you want to try other brands, read the reviews. Some squeak and some fade.
I use Mexican made Brembo rotors. They work well but they rust quickly, so the brakes squeak a bit the first time you press them after washing the car or driving in the rain. More expensive rotors or BMW branded rotors don't rust so much, but they cost a lot more and don't necessarily last any longer.
After replacing the pads, turn the key to the On position and leave it on for about 90 seconds before starting the car to reset the brake pad warning light.
2answers
What would be the causes for brake lining study light to come on in a bmw x5 2005.
Study light? Do you mean warning light?
There are sensors clipped into the brake pads on the front left and rear right wheels. When the brake pads get very thin, those sensors rub on the brake rotors, and the light illuminates in the dash indicating that it is time to replace the brake pads.
The light can also illuminate if something damages the wire to the sensor. I usually replace my pads before they get down to the sensors, so I re-use my old sensors. Although the wires are fairly well secured to the suspension, after a few years, the wires can get chaffed from the wind blowing them around, and the damaged wire can turn on the warning light.
Feb 27, 2011 • 2005 BMW X5
2helpful
3answers
2000 BMW 528i After driving the car for 11 minutes the rear brake warning light comes on. Also, the yellow brake warning light has come on a couple of times as well as the yellow triangle with a curved...
  • Replace rear pads and wear sensor.
Hold milage reset til you see test then toggle through it pro forms test and resets. Check YouTube for further info
1helpful
Brake pad wear indicator light does not go off at the dash after changing rotors brake pads and the sensor in the front wheels all pads and rotors and the sensor is ok at rear. the vehicle has only 30000...
Did you change the sensor? if you did, do a battery reset (disconnect for 10 to 20 min.).
Obviously the wear sensor has made contact with the rotor and is already damaged. You're not even suppose to resuse the wear pad sensor if its worn or damaged anyways.The way how the sensor works is that it must make contact to the rotor to complete the wear pad light indicator circuit. There is no mentioning that he replaced the the wear pad sensor with a new one.
But if one did replaced the wear pad sensor and the wear pad indicator is lit up, the way to reset it is to leave the key on in ignition switch #2 or #1 for about 30sec. turn it off and its reset.
Its possible that you forgot to replace the brake light sensors. They are about 15 bucks, and have to be replaced in order for that light to turn off. You can either get them from the dealer where they'll likely charge you 3 times as much, or you can go to http://www.turnermotorsport.com and get them there.
You have to reset the light by leaving the ignition switch on position #2 for about 30 sec. turn off the ignition and start the engine up and see if it goes out. I recommend buying a new wear pad sensor as well because now light will lit up when you're way below spec (less than 3mm)
Also, you could try with this procedure for one E39: Turning off the Check Brake Linings warning on the Instrument Cluster...
- so you've just changed the brake pads on your E39, along with the wear sensors. The old sensor(s) needed replacement cause you waited a bit too long before changing the pads, and wore through the sensor(s), turning on the BRAKE light on the dash. But wait, the light is still on? But there's a new sensor installed... what gives?!
- there is a procedure required in order to turn off the light/warning. With the ignition off, step on and hold the brake pedal. Now, while holding the brake pedal down, turn on the ignition switch to position 2 (just before cranking). Hold the brake pedal until the BRAKE light is off. Tada, the warning is gone and reset.
NOTE: This procedure worked on a 2001 E46 325i. It took about 15-20 seconds, but it cleared out w/o having to unhook the battery.
Other details find in the Owners Manual 2006-BMW-Z4m-Roadster-Owner-Manual
Keep us updated.
1helpful
2answers
My DSC and Brake warning lamps continuously light up in yellow once the engine has warmed up. They remain on after driving for a while and sometimes they shut off. Any ideas?
Check to see if your brake pads and rotors are in good condition. Or if you have replaced the pads yourself and have not reset the wheel sensors this would cause the ABS Antilock Brake System light and the ASC Automatic Stability Control light to stay on as the ASC uses the ABS brakes with computer assistance to control the car
5helpful
I have 1998 bmw 528i, the problem is when the ASC light come on, the automatic transmission won't go into gear. and this only happen in low gears
Check to see if your brake pads and rotors are in good condition. Or if you have replaced the pads yourself and have not reset the wheel sensors this would cause the ABS Antilock Brake System light and the ASC Automatic Stability Control light to stay on as the ASC uses the ABS brakes with computer assistance to control the traction of the car if not fixed it can affect your rev limiter and slow performance
2answers
Resetting brake warning lamp 2006 bmw 750 li
you will require to take the car to a dealer to resett this
BMW 5 series - 2005 model - resetting service & waring lights
the brake pad warning light is controlled by a sensor located in the front and rear brake pads, small contact with 2 wires that plud into a harness, if they are bad I think the replacement cost is around 5-10 dollars for a new one, there will only be one in the front and one in the rear, the service light is turned out by a special tool at the dealer
4helpful
3answers
BRAKE WARNING LIGHT
I dunno if this will work on your BMW, but on my BMW Z3 and M3, it was....
Turn the ignition key to position 2, but do NOT start the car. Wait for about 45 seconds and the brake warning message will be reset.
If it doesn't reset, then the brake sensor was damage. You will need to replace the brake sensor. It sounds like you replace the brake right after you saw the warning, so the brake sensor should be okay.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
