Question about Boating
Haswing trolling motor, power on , 3 lights , have reset the machine but it wont run the motor, or turn . Jim
Posted by James Haskett on
  • 1 more comment
  • Frank Thompson
    Frank Thompson Nov 19, 2019
    My Haswing Camden remote stopped working and found that my remote battery was dead. Plug in foot control worked fine. Recharged remote battery by buying a AC 100-240 V USB DC 5V 500 MA Charger on e-Bay $4.99 free shipping received it in 3 days. Charged battery through connector on end of remote overnight remote and trolling motor work fine
  • Joe Monaghan
    Joe Monaghan Oct 22, 2020
    Do you remember the part #?
  • Joe Monaghan
Marvin
    Top Expert:
  • Boating Master
  • 85,239 Answers
Have the battery pack tested.
Posted on Oct 20, 2017
5 Related Answers
hibfishers
SOURCE: I have a great white 67 lb thrust trolling motor .
Sounds like it's heating up. Check your wire size. For 24 volt: 6 guage wire is reccommended - that's pretty heavy. Also check the wiring of your batteries. It's easy to get mixed up if you have 24 or 36 volt system. One more thing...check the fuse size to make sure that is correct. Hope this helps. Brian
Posted on May 02, 2009
Anonymous
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
Posted on Jul 15, 2009
Anonymous
  • 11 Answers
SOURCE: There is no power going to my trolling motor but
try spraying electronic cleaning grease and protectant on both areas
Posted on Aug 22, 2010
Andy G
  • 3 Answers
SOURCE: i recently purchased a shakespeare
Have you tried pushing the button on the end of the handle (where your thumb is)?
Posted on Sep 02, 2012
goldbill
william moore
  • 184 Answers
SOURCE: I have a 2007 Suzuki df70 4 stroke outboard motor that when put in a higher gear than trolling sounds like a tapping noise coming out of motor, also a loss in power.(noise sounds like a card that a ki
Most manufacturers demand the water pump be changed every 3 years.
If your thermostat sticks, you can over heat. You would also need to ignore or have a failed temp buzzer. Also at extreme temps, your temp sensor can burn up. SO if you heard the buzzer, and then it quit- that did not mean you were out of the woods.
If you could still run on your scalded pistons, I would think a light bore job with new pistons would fix it.
Posted on Oct 14, 2012
On haswing trolling motors are the battery percent lites suppose to stay on all the time
Yes that would be the normal operation of the indicators
Jun 26, 2018 | Boating
Great white wont turn motor runs but wont turn
Do you mean you can hear the motor turn but the propellor doesn't turn?
Then check the break-pin of the propellor. It's a security device that will break when the propellor hits an object in the water...
Sep 27, 2016 | MotorGuide Great White Saltwater Series...
Aug 03, 2012 | Suzuki Boating
Have 12 V bow mount trolling motor that doesn't start working until power is on for about 5 minutes. Then when it does start, have to have the power on 10 just to keep the prop moving. Checked prop and...
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Sep 18, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have a Minnkota Riptide 80# thrust trollmotor.I have power to the head but motor will not run. It is a bow mount with twist grip control.When I mash on the power indicator button ,it lights up showing I...
1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
Nov 23, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
New MotorGuide VariMAX trolling motor does not run
May 23, 2009 | MotorGuide Electrical Supplies
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
[email protected]
Mar 01, 2009 | Minn Kota Boating
Boating Logo
1,031 people viewed this question
Top Boating Experts
ray gallant
ADMIN Canada
ADMIN Canada
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
