Computers & Internet Logo
Question about LaCie Computers & Internet
My LaCie 324i monitor will not turn on. Can I repair it?
Posted by Gary Ungefug on
gary433
    Sergeant:
  • LaCie Expert
  • 253 Answers
You can try a new lead or power supply. If it is internal just buy another monitor as not a DIY repair
Posted on Oct 18, 2017
5answers
Lacie 324 screen turned blue
yeah mine too ... was working fine then came up Blue screen. switched back to another laCie 324 monitor happen to have. Called LaCie who said they only replace these as it is cost prohibitive to repair or service... oh and I had it 18 months and they wanted me to pay for a new one and after I send it back if it is not working and is covered under warranty they will reimburse ... what kind of customer no service is that.
1helpful
Turns on, no video.
How do you know it's recognizing the input? Black screen on a CRT monitor usually mean the horizontal output circuitry has failed impeding the flyback from producing high voltage. If this monitor is really important to you most reputable repair people still repair them. However, it may be overall cheaper in the long run to dump it and get an LCD monitor.
I have a LiCie electron Blue crt monitor. I have
You have a bad connection or break in the wiring. Fix that and your monitor will work properly. Could be the wire itself or the plug you use to plug into.
LaCie Photon 19 Vision streaks and has visual distortions.
One thing you could try is unplugging and replugging the video cable from the monitor and from the computer, I have often found that fixes a blurry monitor.
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Sounds like this one needs component-level troubleshooting in the power supply section.
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
3helpful
6answers
Screen goes black with bright white horizontal line
This problem of loss of vertical deflection with the line offset from center suggests a cold solder connection in the vertical sweep circuit or in the power supply to the vertical sweep circuit. Most service shops should be able to fix.
Top LaCie Computers & Internet Experts
Marvin
Marvin
shadow
Mike
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
