SOURCE: How do I install a replacement Frigidaire over the
Remove everything from the inside of the microwave, (such as glass tray). Unplug the microwave, probably in the cabinet above. There are two screws in the cabinet above the microwave, near the front, that supports the front of the microwave. The back is hooked on a mounting plate attached to the wall behind it. An assistant is a good idea though this can be accomplished alone. It is best to move the stove out, if you are going to try alone. Please be carefl there is considerable weight to support here. Support the front of the microwave while the two screws are removed in the cabinet above. Slowly tilt the front of the unit down until you can pull the cord out of the bottom of the cabinet. With the front still tipped down, lift the back from it's support and remove it.
