Avantco Refrigeration Avantco CFD 2 Door Reach In Refrigerator Stainless Steel 120V - 46.5 Cubic Feet Logo
d
dalal saliba Posted on Oct 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Avantco refrigerator is leakingg water from inside on bottom shelf, what could be the reason,?
marlin siecinski
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 512 Answers
  • Posted on Oct 23, 2017
marlin siecinski
Expert
Level 2:
Prodigy:
Answers
512
Questions
Helped
160216
Points
715
Sounds like you have a plugged drain tube. You can look in the back in the compressor compartment and look for a hose about the size of a chapstick. try a turkey baster to push air or water in it , or a small wire to clear the blockage.
Always disconnect power before attempting to repair any electrical appliance
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 18, 2008
SOURCE: Estate TT21AKXKQ Refrigerator Leak
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Anonymous
  • 29 Answers
  • Posted on Jan 29, 2009
SOURCE: Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Apr 27, 2009
SOURCE: water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Anonymous
  • Posted on Jan 04, 2010
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on May 17, 2010
SOURCE: we have water laying on the bottom shelf every day
Under the evaporator coils is a drain. It catches the defrost water and directs it to a pan above the compressor where it evaporates. The drain clogs and water cascades down the back wall ending up under the crispers. Get a shop vac and open the drain.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Leaking a lot from water filter, which is inside and on roof of refrig.
Has the filter ever been frozen? that can cause it to crack. If not, it is probably going to be the filter head that has failed seals... Whirlpool Refrigerator Water Filter Housing WPW10238156
How to remove bottom shelf to clean inside bottom of freezer?
Good Morning Wayne,
I see that you want to remove the bottom shelf of your Frigidaire freezer, to clean inside the bottom of your appliance. To remove the shelf, you will pull it out and lift it up. If you are having troubles getting the bottom shelf out, I suggest contacting a local authorized technician for further assistance. They will be able to diagnose exactly what is causing the shelf to stay inside your freezer. Hope this is helpful.
-Best Regards-
WP
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
2answers
My ice cubes have a funny odor/taste.
Does your refrigerator have a water filter? if it has one it will be in the kickplate/grill below the freezer door. If it has one replace the filter.
There is water frozen on the lowest shelf inside the freezer. I believe the drain is clogged but dont know how to get to it
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
I have Ice on the bottom shelf of the freezer.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Our freezer sat in the garage unused and unplugged for about a year. Now we are ready to use it so we plugged it in. Its been on about a week now and its still not getting cold inside. Actually I...
something easy to try is to clean the evap. usually on the bottom. warm soap and water, or compressed air usually does the trick. it's the easiest thing to try.
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 • Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 • Freezers
2helpful
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Top Avantco Refrigeration Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Avantco Refrigeration Freezer Expert? Answer questions, earn points and help others
