Watches Logo
Question about Colibri Watches
Replacement battery for 3 volt cr1240-e
Colibri lazatron lighter
Posted by howard goodridge on
Rick Lillard
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
It's not rocket science, they have them atPetsmart and most pet store box stores, CR1240E-T lithium 3 volt battery is a dog shock collar battery.
Rick
Posted on Jun 10, 2019
Bryan Bogus
    New Friend:
    Problem Solver:
  • 9 Answers
Bob's battery.com
Posted on Oct 25, 2017
3 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Colibri lighter
Usualy there are screw at the bottom.
If there are no screws at all. that means the lighter is assembled in 'click-on' way and you have to use your imaginary engineering skills.
Start with a part which looks attached to lighter the last.
Posted on Dec 21, 2008
Anonymous
SOURCE: battery required for colibri lasertron
This lighter would normally use a CR1240E-T lithium 3 volt battery. If you still have an old flat battery, it can be charged if you know what you are doing. OK, so you don't have an old battery, so there are 2 types of battery that you can use to sort the problem. A lot of advice out there suggests using a CR1225, with a little packing to make up for the lack of thickness, this I have found barely works, as the capacity is so low to start with. And now for the real solution........ I use two silver oxide 391 batteries (11.6mm X 2.1mm @ 1.55volt each). With bits of paper to insulate the positive poles from shorting, and more paper to insulate the screw down cover from touching the top battery. The whole thing takes only a couple of mins, and you'll have months worth of bright red light and powerful sparks. Good luck John P. [email protected]
Posted on Jan 01, 2012
Anonymous
  • 69 Answers
SOURCE: what battery to put in colibri sensatron lighter
303 or 357. when you take old battery out it may be diffrent number need to convert number / use retna battery chart
Posted on Feb 02, 2012
Looking for replacement battery for colibri beam sensor lighter
I repair Colibri lighters and many other brands and models.
I repair all butane lighters including the beam sensor and touch sensor models.
[email protected]
2answers
Colibri cx gear 35002 butane lighter
I.ve got a lighter its silver crome alluminum it reads on both sides a big X with a c on top and us on bottom its butane on the bottom it has a signiture I.D it looks like a snake going up a stick can you help me idenify this lighter it's driving me nuts Thank You Lily
Sep 22, 2012 • Watches
I have a Colibri BOSS cigar cutter lighter. As usual the handles for the cutter have broken away from the blades. The handles are riveted to the blades and so I need at least on blade/handle combo. In...
I have replacement cutter blades for colibri boss lighters.
[email protected]
1helpful
Battery required for colibri lasertron lighter
My colibri lighter does not want to light up. Have bled tank and refilled. Only a small flame appears.
[email protected]
1helpful
Colibri lighter
Dec 20, 2008 • Watches
Top Colibri Watches Experts
Marvin
Marvin
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Colibri Watch Expert? Answer questions, earn points and help others
