Question about Whirlpool Cooktops
My electrician needs this info because he is unsure if the cable is large enough after removing a westinhouse side by side wall oven and cooktop. we have not sighted this wall oven as it is a private negotiation
SOURCE: stove burner/ maytag double oven
did you use ajax or any cleanser that might leave a powdery residue is any of the air/gas holes clogged is the burner clogged internally, can you put anotheer burner in that place to see if it is the burner check it out.
Posted on Jan 04, 2008
SOURCE: Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
Posted on May 22, 2008
SOURCE: Whirlpool Gold ceramic cooktop removal.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
Posted on Dec 16, 2008
SOURCE: I need to remove my Whirlpool Gold ceramic cooktop.
SOURCE: whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 06, 2009
Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
Nov 08, 2014 | General Electric GE 24" Single...
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
Sep 07, 2014 | Frigidaire Stove / Oven / Range Cooktop...
Apr 16, 2014 | Kenmore Cooktops
Feb 12, 2014 | Frigidaire FGGF304DLW Gallery 30"...
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
Dec 25, 2012 | Whirlpool GGE388LXB - Black GoldR Double...
Nov 11, 2009 | Kenmore Cooktops
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Aug 11, 2018 | Whirlpool Cooktops
174 people viewed this question
