Question about Icom Radio Communications
I want to know how to do hard reset on the ICOM IC-M802. Thanks.
ICOM M802 worked fine yesterday but today the screen displays IC-M802 MMSI--no mmsi ! and the screen is frozen.
Posted by Alfonso Ebanks on
Clint Millett
    Habit-Forming:
    Scholar:
  • 97 Answers
The link below should help you. Lots of info in the service manual. It's intended to let someone rebuild the radio from the ground up.
Posted on Nov 10, 2019
3 Related Answers
Anonymous
SOURCE: need to install new MMSI number
http://www.raymarine.com/SubmittedFiles/Handbooks/Communications/81231_2www.pdf
Check the instructions on page 61 of the manual (link above)
Posted on Dec 29, 2009
Anonymous
SOURCE: how to reset mmsi number Raymarine 215
This secret code is for the Raytheon / Raymarine RAY 220 VHF. It may work on other Raytheon/Raymarine radios also.
Here you go:
With the Power OFF, Press and HOLD the FUNC, 16/9 and DSC keys while you power ON. Do not release the keys until you hear the audio BEEP which means your done. Then reprogam your NMSI number as per the manual. Pretty easy, hey?
Posted on Nov 17, 2010
Anonymous
SOURCE: need to reset the mmsi
Did you ever solve this problem. I have just purchased a little Leisure 17-SL with a fairly new one of theses radios. I have the handbook and discover you can only program the MMSI once and then return to a dealer to clear it!
Many thanks
Steve http://www.withamweather.co.uk
Posted on Dec 16, 2010
WHERE can i get by MMSI NUMBER from on a boat VHF RADIO
here
https://www.boatus.com/MMSI/MMSI/ObtainMMSI#!
Mar 05, 2018 | VHF Boating
Where can I get my MMSI number form
from the marine authority in your country ?
if you were from the usa it is
https://www.boatus.com/mmsi
However I don't know which part of earth you do your boating in ?
google search mmsi and add the country you are from ?????
Mar 05, 2018 | Computers & Internet
ICOM M802, can't run SEA 1612C coupler.
uk-repair.com/repair/hard-reset/icom-radio-marin-ic-ssb-m802/369/6891.html
Try this site
Oct 18, 2017 | Icom Radio Communications
Entering my MMSI number i can get to the setup screen but won't go to the next step
Has it ever been setup for a MMSI? If so, I think they can only be set once and need to be cleared by the factory to be ready for a "new" MMSI to be entered.
May 30, 2015 | Uniden Um380 Black Vhf Radio Class D
How do I enter an MMSI number into my Uniden UM415 It is useless to call Uniden, I have already wasted 3 hours on hold with them.
Hi Peter!
NICE radio Man. You're right, Uniden customer service is horrible.
Ok, here's the deal. You HAVE to get this right the first time, otherwise you pretty much have to send the unit back to Uniden.
Press and hold CALL until the setup menu appears.
Press ENT (1W/25W), that gets you to the user MMSI portion of the program.
NEW should be what you see on the screen.
Press ENT. That'll get you to where you actually get to enter your number.
Using channel up or channel down, set the first number.
ENT
The cursor moves to the next digit.
Repeat until your full MMSI number is entered and displayed on the screen.
IF YOU MAKE AN ERROR, don't panic, press clr/scan and the cursor will move back one spot to the left, erasing the wrong digit.
When the ninth digit is correct, press ENT. The screen will display your MMSI number and ask you to confirm. To save, select yes. To cancel, select no.
Before saving the number, your radio will ask one more time if you wish to confirm and warn you that this is a permanent setting.
Press ENT to confirm, or CLR to start over again.
Hope this helps.
-Steve
Oct 15, 2014 | Boating
Need to reset mmsi number
I don't think the RAY100 is DSC compatible and therefore doesn't have the MMSI programmed into it. Most manufacturers limited the number of times that the MMSI can be programmed to one (!). After that, it has to got the factory or to an authorized dealer who can bypass the restriction.
Mar 28, 2014 | Raymarine Ray100VHF 2-Way Radio
Mmsi reset icom
You've not given much info here, we need not only the Make (Icom), but the Model No. as well to be able to assist you. Could you pls re-post all details of your radio, so that we can follow up on your query.
Cheers, [email protected] Team
Nov 21, 2012 | Radio Communications
Need to reset the mmsi
Many thanks
Dec 14, 2009 | Icom M302 VHF Radio
Radio Communications Logo
315 people viewed this question
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
