Pool & Spa Logo
Gary Lloyd Posted on Oct 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacement heating element for life smart 2 person sauna
Blake Strickland
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Dec 20, 2017
Blake Strickland
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
2681
Points
233
I finally completed my sauna! I decided to use an electric heater, that's what I have - Spaprof com (SAWO SCANDIA COMBI 6.0KW)it works perfectly, there were no such problems.
Jack Evans
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Dec 06, 2017
Jack Evans
Expert
Level 2:
New Friend:
Answers
51
Questions
7
Helped
7854
Points
251
Use an electric heater
2answers
2answers
Infrared sauna room (2 persons) Does anybody know what EP stands for or/means on the temperature control panel???
check to see if filters are clean if so see if recirculation pump is working if so check heater fuses if blown probably bad heater element
Sauna wont get hot enough
When I'm in a traditional sauna like this, I expect the temperature to be between 70 and 90C so that's what I assume you are trying to reach. There could be several reasons for this so make sure each point is checked:
1. Stating the obvious, to increase the temperature inside the sauna, you'll have to ladle water onto the hot sauna stones.
2. Maybe the insulation within your sauna isn't good enough and heat is escaping.
3. Your sauna room could be too big for this heater to heat properly.
4. Maybe the element on the heater isn't performing properly and needs to be replaced.
These were some pointers which Di Vapor gave as possible reasons for lack of heat.
Sauna Electric Heaters Spares
The big infared panel does not work, what can i do?
be looking for fuses or connections .. does it have power??
My viking sauna will not get hot.
I don't know what a sauna has to do with sewing machines... but I suggest that you locate and test the heating element.
2answers
I have problems with the power of mij sauna. were
Did you get an answer to your question. I am also looking for s126smd3 to buy.
Heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
1helpful
I just bought a house with an amerec sauna. The
the 'easy' answer would be a tripped high-limit switch. Inside the generator box, there is a resettable circuit breaker to the heating element, on the top of the water tank.
kill the power to the unit, take off the shell and look for the pushbutton.
If that is the problem, there is a likely chance that the temp sensor in the shower is not working so it overheats and trips the high temp limit.
Top Smart Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
