Question about UTStarcom Cell Phones
Where is sim card on utstarcom
Need to know where SIM card is on a UTStarcom cdm7176
Posted by Gordon Barton on
buzzcola
  • 7 Answers
That phone doesnt use sim cards. In the U.S., there are two different cellular technologies: CDMA and GSM (most of the rest of the world uses GSM). Up until 4G-LTE came along, CDMA phones didnt use sim cards. The cdm7176 is an older CDMA phone and thus doesn't have a sim slot.
Posted on Oct 17, 2017
5 Related Answers
Anonymous
  • 83 Answers
SOURCE: Razr V3: Subsidy unlock code?
Download this unlocker. Unzip it somewhere you will remember.
http://dl1.rapidshare.de/files/689909/63115315/Motorola_Unlocker.zip
1) Turn Off your phone
2) plug your phone to the PC using your mini usb cable
3) put your phone on the flash mode *,#,and power button
4) open the software
5) click on connect RFone
6) click yes
when it say done it is unlocked
This info is in motodude sig just find a post by him and you will find many links that are usefull for motorola phones.
Posted on Aug 23, 2008
Anonymous
SOURCE: UTStarcom CDM7126 etiquette mode
hold star button on the phone and it will enable it
Posted on Feb 24, 2009
Anonymous
  • 464 Answers
SOURCE: locked utstarcom model cdm7126
Call your cell phone company. They have a master code to unlock it. That should be the quick fix :)
Posted on Mar 19, 2009
Anonymous
  • 24 Answers
SOURCE: need drivers
get it from www.download.com
please give me ratings....
Posted on Aug 25, 2009
Anonymous
SOURCE: utstarcom um100c modem drivers for windows 7
1. Start the install process as normal, you will get to the section that asks you to plug in the um100c.
Windows will not automatically install these drivers for you.
2. Leave the setup program running and open up Device Manager
3. Find UTStarcom UM100C under unknown devices.
4. Manually search for the driver in "C:\Program Files (x86)\Cricket\QuickLink Mobile\System\driver".
After it installs there will be two more unknown devices in Device Manager. Repeat the manual driver lookup in the same location to install them.
5. After that go back to the setup program, you should now be able to click on Next to finish it.
Posted on Jan 24, 2010
Where is sim card on a utstarcom mobile phone
Depends on the phone but most likely it's under the battery. If not there, then look for a slot on the side of the phone, covered with either a small rectangular piece of rubber or an easily removed piece of hard plastic.
That being said, some models won't have a sim card. It depends on the carrier and the phone. Sprint, Verizon, & others that use their networks (such as Virgin) only started using sim cards when 4G LTE was launched. If the phone isnt designed for LTE and the phone is a CDMA phone (the technology that Sprint & Verizon use) then it wont have a sim card unless it the phone was also designed for use abroad (E.g. Europe).
Oct 17, 2017 | UTStarcom Cell Phones
Need to unlock my UTSTARCOM phone
what is mobile model? if it is UTStarcom GTX750R you can get it unlocked through codes from Onlinegsmunlock.com
Feb 16, 2012 | UTStarcom Cell Phones
I accidentally turned my phone's main lcd lights on "always off" and I can't seem to turn back on the screen. I need help on trying to turn back on the screen, it's not broken or...
try taking your battery sim and memory cards out wait a few minutes and replace turn off the phone first, you might also try your provider and they will run through the sequence , if you have your manual you should be able to go through it blind, hope this helps good luck,regards terry
May 17, 2011 | UTStarcom Cell Phones
SOMEONE LOCKED MY PHONE AND I CANT GEt IT UNLOCKED
i have an lg290c phone with no sim card cant get the browser to work
Feb 25, 2010 | UTStarcom Blitz Cell Phone
My daughter locked my phone and it's a utstarcom phone and I can't unlock it to call out or doanything on my phone whithout a pin. What do I need to do?
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Jan 18, 2010 | UTStarcom CDM7025 Cellular Phone
Locked utstarcom model cdm7126
Mar 18, 2009 | UTStarcom CDM7025 Cellular Phone
Cell Phones Logo
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
