Question about Lexmark Office Equipment & Supplies
Will not scan everything else works fine have tried everything lexmark suggests and other help sites
Posted by Chuck Burch on
3 Related Answers
acdr
kishor khatri
  • 1913 Answers
SOURCE: X1240 Lexmark
u have to down load scanner soft ware from the folowing link
http://www.softwaredriverdownload.com/lexmark_x1240_printer_driver.html
Posted on Sep 30, 2008
Anonymous
  • 58 Answers
SOURCE: I have tried to install
You need to install Vista drivers for this printer!
Posted on Feb 19, 2009
adibron
Adi Bron
  • 83 Answers
SOURCE: My printer scans and previews
it's probably because the scanner isn't configured well in the computer. What you should do, while to printer is turned on and connected to the computer is to go to the device manger (right click on "my computer" or "computer", and then go to the tab named "device manager"). go to "universal series bus controllers" and press on the plus sign. you should then have a list, search for "USB composite device" in that list. when you find it, right click on it and then left click on "uninstall" or "remove", approve it (press yes or OK) and after it done, disconnect the usb cable that connects the computer to the printer and restart the computer. only after the computer is booted up completely, you should reconnect the cable. after you do that you should get a pop up that says that new hardware is being installed (or something like that). wait for it to finish and after it says "you new hardware is installed and ready" (should appear near you computer clock), try to scan, it should work fine now. Good luck!
Posted on Jan 28, 2011
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
One side of scan appears super bright to white , like the document is not touching the glass on that side . Why ?
  • Log on to the Lexmark website and update the driver. Also try and run diagnostics and see if that lists a fault.
Jan 19, 2018 | Lexmark P4350 All-In-One InkJet Printer
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X4580 cannot scan, as although it recognises my PC and when I press the tick it states "downloading application list it thinks for ages and then states "unable to retrieve application...
This appears to be a known error on this model of Lexmark including all the 3500-4500 ranges... there are a couple of download patches on the Lexmark customer support site at lexmark.co.uk, I simply followed the instructions and the first patch worked fine......
Jul 15, 2008 | Lexmark Office Equipment & Supplies
Lexmark error message hardware error 0502
Clean the rollers that the cartridges run on with a non-lint wipe (i use non scented baby wipes for all my printer work. The printer should now run fine. cheers lilacgerry xxx
Jan 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 will not scan
Try resetting you machines by turning off and unplug, reverse steps and try again. If no go, repost and we will try again. Cheers lilacgerry xxx
Jan 09, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark series 2480 won't scan
whats the answer to this????!!!!
Nov 24, 2007 | Lexmark X3100 Flatbed Scanner
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
