Video Game Consoles & Games Logo
Question about Saitek Video Game Consoles & Games
Can I get my Saitek Pro Flight Pedals repaired?
Posted by Terry OBrien on
5 Related Answers
Anonymous
SOURCE: Saitek pro flight multi panel won't work
exit present flight to general menue, minimize so you can access the "start" button then go to programms/saitek and select "lauch the Flight Sim 2004 plugin". All will work well.....exect the trim wheel acts in reverse!!
Posted on Jan 18, 2010
Anonymous
SOURCE: Saitek Pro Flight yoke and quadrant stop working
Seems to me va power problem if you have a lot of other usb components running then you will need auxillary power, you have two choices really, the aformentioned USB card and fit to your MB
Or purchase teh Saitek power supply, and power the yoke direct.
I had the same problem and solved it by removing one of the usb devices form the yoke and putting it a usb slot on the rear of the computer. Mind you I have all the saitek panels as well.
hope this helps
Posted on Feb 17, 2010
Anonymous
  • 122 Answers
SOURCE: saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Posted on Jul 12, 2010
Anonymous
  • 122 Answers
SOURCE: Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Posted on Jul 16, 2010
Anonymous
  • 122 Answers
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Posted on Jul 18, 2010
Loaded XPlane 10 on new iMac and rudder pedals no longer function?
My iMac has a CD/DVD drive, but I posted a X-Plane 10 pendrive to avoid inserting DVD #1 every session. It functions perfectly. Another point is to connect all peripherals (stick and pedals etc.) BEFORE launching X-Plane 10. Then calibrate your peripherals within XP 10.
I have no pedals set, but instead a pitch-stick with grip throttle and a Logitech joystick with twist grip to fly helicopters.
I have a simple problem with the SAITEK pro flight yoke. The LCD display is backlit, but BLANK. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LCD DISPL
If the LCD is not working then it is likely that required drivers are either not working or missing. Try downloading updated drivers from the Saitek website.
Saitek Pro Flight Yoke Suddenly Stops working.... Usually when i switch on my pc, the yoke will also turn on as well by looking at the green light at the timer screen on the yoke....but now when i on my...
Try basic troubleshooting first, try to remove and reconnect the ps/2 and usb of the saitek pro flight, also try to put it in different usb ports to see if maybe a usb port is not working, lastly when all else fails try to connect it in another computer and see if it works.
Saitek pro flight yoke problem
Hi, I contacted Saitek approximately 2weeks ago regarding the blueand purple backlight failure on my Eclipse II keyboard. I am awaiting your reply. I now have, what I feel to be a more serious failure on...
Hi Chris
Ensure that you have the usb lead from the yoke plugged into the rear of the PC as these give the most current. Ensure the drivers for the yoke are installed properly and they are the latest for your operating system. If this still does not work, then the yoke is faulty. Good luck!
Top Saitek Video Game Consoles & Games Experts
Marvin
Marvin
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
