Question about The Watches
Anybody know how to pop barrel pin back in on a mondaine watch, to restart the watch. See details for more context..
Barrel pin popped out to adust hour hand, and now will not fully push back in to restart the clock...not happened before.
Posted by Timothy Barsellotti on
Geoff
    Dedicated:
    Visited the website for 20 consecutive days.
  • 125 Answers
Mondaine is a quality Swiss manufacturer of watches, so they will use decent quality mechanisms/movements. You don't say if it is a quartz or a mechanical movement.
I assume by 'barrel pin' you are referring to the crown. Check that the crown is not a screw-down one. Try turning the crown slightly before trying to press it back.
It's possible that there is a fault with the 'latch' that holds the crown and stem in place. Do not attempt to force the crown back in!
If gentle persuasion fails to get the crown back in, I'd suggest a trip to your preferred watch repair centre.
Posted on Oct 17, 2017
  • Timothy Barsellotti
    Timothy Barsellotti Oct 17, 2017
    That is super helpful Geoff. It is a quartz watch (battery powered). It may have to take a trip to the watch repair centre. Many thanks
5 Related Answers
Anonymous
SOURCE: Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Posted on Jan 26, 2010
Anonymous
  • 33 Answers
SOURCE: watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
Posted on Feb 27, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: does anybody know which way
mcdevito75 here, Generally your Cartier watch is wound in a clockwise direction simply, due to how it:s made, in this direction the mainspring is tightened or wound and turning the crown in a counter-clockwise position only free wheels the winding mechanism. I would advise you wind your watch in a multi direction, however not to the very, very end of It"s winding capacity, once you feel the crown getting tension only 4--5 more multi-direction turns should be enough to maintain a good wind to your Cartier watch.
Posted on Aug 15, 2010
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: I have a Nexxtech Watch
These basic instructions are for most digital watches (and these are for regular to military but you can just follow same instructions to get to oposite) Hope this helps!
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Posted on Aug 21, 2010
Testimonial: "Thank you very much. That was easy."
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: fossil wristwatch: hour and minute hand not in sync
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
Smith and Wesson model 2206 LR 22 Semi-auto
The tip of the barrel. The muzzle. That doesn't make very good sense, since the barrel is one piece, surrounded by the slide, which is also one piece. Is it possible that you need the front sight?
You will very probably need to take it to a local gunsmith for repairs.
Jul 30, 2014 | Smith & Wesson Smith and Wesson Stop Watch...
Tip
MONDAINE watch manuals
Follow this link and download manual for your MONDAINE watch: <a href="http://www.mondaine.com/after-sales-service-mondaine/">http://www.mondaine.com/after-sales-service-mondaine/</a>
on Feb 26, 2011 | Watches
Date mondaine classic
You tell me from these sites:
http://www.watchco.com/mondaine-watches/evo/a667-30314-11sbb.html
https://www.squiggly.com/us/en/mondaine/classic-daydate-white-a667-30314-11sbb.htm
Jan 23, 2013 | Mondaine A667.30314.11sbb Classic Watch...
Mondaine Retro automatic day date are not aligned. Date also skips occasionally
Hello Tom Bott,
The Mondaines I have seen a big, bold,
beautiful watches...
Sorry...!!
If it is INDEED NEW... ("The other week")..
I would take it IMMEDIATELY back & get another.
Day-Date watches can INDEED be damaged by
moving the DAY/DATE inside specific times
around midnight...
Most watches
can handle the ABUSE but some
cannot... (keep in mind it could actually be defective).
The watch will not heal itself... and unless you failed to put the stem/winder all the way home... SOMETHING is tragically WRONG with your watch.
My BEST ADVICE... exchange it (now).
Mondaine Men Swiss Railways Giant Watch A6603032811SBB
Carnac the Magnificent
May 04, 2017 | Watches
Ive had my Seiko automatic titanium scuba 200m about 3 years when i got it, i had it sized down by taking out 3 links which the store gave me back and 3 pins that go with , ive put on a few pounds maxed...
Thanks for contacting FixYa.
Seiko normally will send out up to 5 extra links on new watches. I am not sure on watches that are 3 years old but you will need to contact Seiko on this one. MAYBE a watchmaker locally will have some extra peices that will work too.
You can contact Seiko here:
http://www.seikousa.com/support/customer/northamerica.html
Best regards.
Jewel
Aug 30, 2010 | Seiko Diver's Watch
Re: Mondaine A692 alrm watch. how do you set the alarm function?
Go to "www.mondaine.com/after-sales-service-mondaine" where you will see a list of downloads.
Unfortunately they do not seem to correspond to the number that you stated but the description might tell you which one is yours.
Mar 07, 2010 | Watches
The hour hand on my Mondaine wristwatch has slipped so that on the hour it is displaced from the hour number. I believe Mondaine watches carry a lifetime guarantee so can it be fixed ?
Yes. The service you are looking for is called a hand alignment. This isnt usually very expensive so you might even try your local watch repair shop as opposed to sending it in.
Sep 18, 2009 | Mondaine Watches
Link pins keep falling out on Ceramic Watch
They probably forgot to put the little locking barrel back in before hammering the links shut again. Some watches have the link, the pin, and a barrel that goes in the link before the pin is hammered in. If your watch needs this barrel then the pin will NOT stay in without it, no matter what.
Dec 29, 2008 | Swiss Legend SL-LUCERNE-ML134AC Wristwatch
Watches Logo
81 people viewed this question
Top The Watches Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
