Samsung 2233sn 1920 x 1080 I have put the settings on the right resolution only i can see half my taskbar. Also i cannot play full screen games only borderless cause of error with screen resolution.
, clicking Control Panel, and then, under Appearance and Personalization, clickingAdjust screen resolution. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply. Click Keep to use the newresolution, or click Revert to go back to the previous resolution.
Change your screen resolution - Windows Help - Microsoft Support
https://support.microsoft.com/en-gb/help/14108/windows-7-change-screen-resolution
How to fix screen resolution Google Search
SOURCE: Video Problems
Hello!
Maybe you need to install the correct driver of your video card. But first update your motherboard driver, if you have CD/DVD utilities enlclosed in your computer from the vendor then you should reinstall that in series installation. after that installation restart the system and then install the updated driver or the current CD/DVD utilities of your geforce 8600 GT and again restart the system after installation. and then set the monitor display to the required display of your games.
May this help, best regards, melnavz
SOURCE: bottom of screen cut off
This is a limitation because of the screen size of the Aspire One. Unfortunately, no fix for that...Sorry
SOURCE: Vedio doesn't play in full screen in my Samsung GT-B3410
In my Samsung GT-B3410 phone videos are not play in full screen after i select full screen. I tried many converters and also with different resolutions. Please tell me the solution.
SOURCE: When i open Cue Club in win7 (laptop model-acer
Check the in game options of the game itself. Somewhere in there should be a check box option allowing you to choose between full screen and windowed mode.
If there is no option, then find the shortcut to the game, and right click on it. Then click on properties. On the command line (that leads to the actual game file) go to the end and see if it has -window at the end of it. (might look like c:\program files\egames\cue.exe - window) if you see that window part (or win in some cases) then delete that and see if that helps.
Don't forget to Rate :)
SOURCE: Dear Sir,
Use total video converter to convert video in Mp4
convert to AVC H.246 MP4 then goto
Setting->video option
in that set Frame rate to 15 and Bit rate to 400 or 500....then convert......its play in full screen in corby plus .......
I use that....and its work........
The desktop screenshot might need reducing Click start "Control Panel." Click "Display" and then select the Settings tab in the Display Properties window. Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply." The screen repaints at the new resolution. Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
