WHO IS THE BEST IC FOR THIS TV AND HOW MANY COST WILL BB PAID
Posted by SOORAJ GUPTA on
  • Anonymous Aug 05, 2020
    OK so you have TV and needs parts.
    NO TV told , no make, no model nor what IC nor its partnumber on its lid.
    impossible question.
    nor can anyone on earth tell you prices of things on a world scale that is silly to think., sorry/
    why not just photo the IC with a camera close
    and post that, be 1000x better no? and TV maker.
Abctay.com
    Master:
  • Televison & ... Master
  • 363 Answers
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Posted on Oct 16, 2017
Bb 8310 said sos no signal
You need to have a paid service and also be within their arena or their roam feature must work. Please contact your cell phone provider and they will fix that problem for you.
Best of it
Gary @ Fix Ya
Jul 20, 2011 | AT&T BlackBerry Curve 8310 Cell Phone -...
The dvd player works, but no tv stations. Tried to go to the tuner and auto program to add channels, but will only delete the channels. I can't figure out why the TV picture won't work. Any ideas?
Hello
There is a memory IC, a very small one having 8 solder leggs, that stores the channel conditions and all other details of picutre, such color, contrsat, brightness, sharpness etc;. Eventhough it small in size, the function with it when the TV works is great. If this IC ahs got damaged, no memory function will be there. From this memory IC, all data are retrived to the main system IC when we switch ON the set after a switch OFF.
When we switch OFF the set, all data at that time, will passed to this memory IC and will be store there. This is a non-volatile type IC [that is even the power to it is switeched OFF, the data stored in it won't lost. And when power comes, the data stored will be retained from it and passes to the main system control IC to process. I think that I've made an idea to you, about how this IC works and how its damage result in working of the TV.
This IC can be located very near to the system control IC, direltly soldered to the circuit board. You have to replace it with same type and number. Insist on same type and number [the number will be printed on it], as this is a very critical component. Won't cost more thatn $4. It can be purchased from most of the electronic spare part shops at your town.
I think that I've made the problem to your Tv somewhat clear to you.
Don't hesitate to rate this solution. Best of luck.
Feb 12, 2011 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Eventually, sometimes after a few minutes, the TV will flip to DVD mode and stay that way. No one has touched the TV or the remote. What is causing this? Can it be fixed?
Hello
Replace the system memory IC. It has been damaged. This IC is a small one, having 8 solder terminals, and wont cost more thatn $4. It can be located very near to the main system IC. Eventhough it is very small, the function of it with the tV circuit when the tV works is great. When replacing it, insist on same type and number. Its number will be printed on its top.
I thinks that I've made a clear indication about the fault to your Tv.
Please don't hesitate to rate this solution.
Best of luck.
Dec 12, 2010 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Whent he tv is on, we see a thin horizonal line. the sound is good...you can hear what's going on, just a black screen with thin horizontal line. TV is only 2 years old. Toshiba TheatreView SD
HELLO
I wish I had a £1 for every time I answered this! This is field collapse where the probable cause is the Field Output IC itself, or dry solder joints on the board where the IC is soldered in.
If you are not familiar with electronics then I urge you contact a service centre in your area.
ALL THE BEST (:-)
Nov 09, 2009 | Toshiba 32A33 32" TV
Green screen then blacked out
Sounds like component has failed (diode, cap, IC)
Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 11, 2009 | Samsung DLP HL-P5663W 56" TV
Identify my Blackberry model
Unfortunately - the advice you gave was totally unuseable. You directed me to a webpage that would charge 59.99 to solve my problem, after I paid 14.99 to you. I then found a service on my own tht solved my problem for 16.99. I can't recommend your service to anybody.
The webpage to solve identification and unlock problems at the lowest cost would be: at least for me- www.unlocktotalk.com.
Sep 27, 2008 | Cell Phones
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Thin Bright line is all I got on the tube
Sounds like a capacitor and/or the Vertical amp Ic has gone out in the set. Maybe a bad solder joint. Depending on where you live, the cost of repair could be between $100.00 to $150.00. Kill it or what? What would Braveheart do. FFFRRRREEEEEEEDDDOOOMMMM
Mar 18, 2007 | JVC AV-27850 27" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
TV SHUTS DOWN AFTER PLAYING FOR VARIOUS LENGTHS OF TIME
what cards? they looks as dosent know what talking abouth, or are ready to fry you, well this sound as a cold solder, but is a job for a tech, $400.00 is the price of new, and thats a $80.00 to $100.00 job in my area, doing in home or in the shop....good luck
Aug 10, 2006 | Toshiba 32A43 32" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
