Question about Sewing Machines
When ever I see it keeps on jamming and doubling the thread over and over
I've been trying to use my sewing machine and it keeps on jamming and it's like the thread keeps looping through and making huge notes at the back.
R.A. Ellis
  • Sewing Machines Master
  • 12,731 Answers
Sounds like thread nesting, usually a result of the thread not being completely seated in the tension disk.
Remove the top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Posted on Oct 16, 2017
Bill Boyd
    Top Expert:
  • 53,816 Answers
Increase the needle thread tension
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: Thread getting caught in machine underneath
Try rethreading the top of the machine making sure you get it thru the tension wheel correctly.. General rule of thumb.
If it loops on the bottom, the problem in on the top.. Loops on the top, problem is with the bobbin.
Posted on Apr 19, 2009
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
jpack76645
Jay Pack
  • 23 Answers
SOURCE: Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
Posted on May 29, 2009
paj42
  • 1116 Answers
SOURCE: Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Posted on Mar 10, 2010
Machine is jamming. Top thread broke so re threaded and re did the bobbin,but it is still jamming every time i try to sew
just found this on the internet...
Fabric jamming in your machine may be caused by the feed dogs. The feed dogs are those tiny teeth along the sewing machineunderneath the presser foot as those teeth pull the fabric through when the needle is making stitches.24 Feb 2016
Why Does My Sewing Machine Keep Jamming?•Sewing Made Simple
sewingmadesimple.net/why-does-my-sewing-machine-keep-jamming/..
or go to this link..
sewing machine is jamming Google Search
Oct 27, 2017 | Sewing Machines
When sewing, it jams up right off the bat.
try rethreading the machine top and bobbin
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint or loose
threads
make sure the top thread has not come off the thread take up lever
Jan 22, 2013 | Sewing Machines
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
try these suggestions
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
Silvercrest overlocker - the 'red' pathway thread won't progress through
have you tried changing the needle?
since you've only had the machine for a week, I'd suggest taking it back & getting another machine.
Mar 26, 2012 | Sewing Machines
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
The thread is tight and it jams
try adjusting the thread tension
check to see if the top thread has come off the thread take up lever--this can cause the machine to jam
change the needle----if the needle is the slightest bit damaged the cause the machine to jam---also the wrong needle for the fabric can cause problems also
try rethreading the machine incase the thread is caught somewhere
make sure the bobbin is in correctly & it's not warped
if you've already done all these things & it still jams up then it could be out of time & would have to be serviced by a repair shop with the correct tools to time it
Aug 29, 2011 | Singer 1120 Mechanical Sewing Machine
The thread keeps jamming under the feed dogs. The machine takes about 2 stiches and then it won't move any more, but it keeps sewing making a terrible mess under plate. What can I do to fix this...
I had the same problem and tried everything you did: rewinding the bobbin, checking to be sure I had the bobbin in correctly, checking the upper threading, readjusting the tension. When nothing I tried helped, I bit the bullet and took it to the shop where I had bought it. The timing was off; there were burrs on the bobbin case; the hook was not performing correctly;there were threads caught between the tension disks. It cost about $65 but when I brought it home, it purred like a kitten! I suggest you take it in for a check up! Especially if you've tried all the usual tests and none of them worked.
I'm sorry I couldn't give you a do-it-yourself answer but sometimes they've just gone beyond what we can do for them.
Jul 24, 2011 | Brother SE350 Mechanical Sewing Machine
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Elna sewing machine
Amy,
did you solve the problem with your Jubilee?
I would suggest that the problem may be not holding the two threads at the back of the needle plate with starting each new seam. Elnas really need you to hold the threads, don't let the tail get caught and pulled back into the bobbin holder area. Once you have one jam, you'll have minute threads you maybe can't see caught under the ring guard (black bit) and the jamming will keep happening. Also, make sure you only use Elna bobbins always with holes on the top.
If you've still got the Jubilee and are having issues with it, feel free to add more info, the other contributors comments about the bobbin being faulty are valid but I dont think your machine is worn out, just jamming. You can remove the bobbin holder yourself and clean underneath it and once you've done it once, and know how to line it and the ring guard back up, its pretty easy and will ensure that the bobbin area stays clean.
Mar 11, 2008 | Sewing Machines
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
