Question about Pets - Others
Can a person get a replacement collar for a Cabelas GS4000
Posted by jim meder on
Zaryab Ghafoor
Keep your dog happy and healthy with the dog supplies they need in every stage of life. Shop for dog and puppy suppliers, toys and products securely at PetsWishlist.
https://petswishlist.com/
Posted on Aug 13, 2020
Tim Marx
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Im gonna go with "YES" for $400 Alex. (daily double)
Posted on Apr 25, 2019
I don’t understand how to sew collar on in B 6107. I’m confused by whether I sew to facings and how I turn collar inside out
Hello, Joyce -
I hope I am correct in understanding you are referring to Butterick pattern 6107. If so, I don't own that particular pattern and accompanying instructions. Am I also safe to assume you do not have the sheet of written instructions with images to accompany the garment pattern? In case you have the pattern pieces but not the sheet of instructions, you may wish to contact the McCall Pattern Co. (Butterick is one of their brands) directly via email here: https://butterick.mccall.com/how-reach-us . Note: They may charge for replacement instructions.
In the meantime, assuming I am correct about your sewing Butterick pattern 6107, I see the coat has 2 collar styles - 1 a shawl collar and 1 a stand up collar.
If you are sewing the shawl collar version, perhaps this online tutorial (with pictures) on sewing a shawl collar will be instructive:
http://sewastraightline.com/2010/10/21/shawl-collar.html
If you are sewing the stand up collar version, this online tutorial (with pictures) may provide the right instruction: http://everythingsewing.blogspot.com/2013/03/adding-stand-up-collar.html
If neither of those resources seem helpful, then you may find an experienced sewer in your neighborhood who will offer to help show you what to do. How to go about that:
- If you are not already a member of the neighborhood web site Nextdoor.com, I recommend you join it (free.) You will be able to identify and limit your "neighborhood" when you register.
- Once you are a Nextdoor.com member, post a question asking if someone in your neighborhood could instruct you in how to sew the kind of collar you wish to sew. Note: I recommend using the private message feature to share addresses and phone numbers.
- There will probably be a kind neighbor or two who will be willing to come to your home and demonstrate to you one-on-one on how to sew the collar and turn it out.
If you would rather not follow the Nextdoor.com route, then, my last option is for you to contact the local public school system and ask for then name and contact information for the person / people who teach sewing (probably in middle school / junior high school) in the school system. Then contact a sewing teacher and ask her/him if you can arrange a lesson with her/him on how to sew your collar. I recommend offering to pay for the teacher's time.
Best wishes.
Nov 30, 2017 | Sewing Machines
Can I buy a custom made collar for my dog? If so, where can I order one?
You absolutely can! I bought one for my retriever and it is fantastic. I will send you the link of the company I used as well as a few other companies so that you have some selection.
http://www.dogids.com/personalized-dog-collars.html
http://www.etsy.com/category/pets/collar
http://www.petcollars.com.au/collections/collars
Have fun customizing you dogs collar - I know I did!
Jul 19, 2012 | Pets - Others
How often should I replace my cat collar?
The only times you should replaceyour cat collar is when one of these thing occur:1) Thecollar become too small and gets too tight around your cat's neck.2) Thecollar look rusty and in bad shape(visually)3) Yourkitty get really irritated by the collar
Jul 18, 2012 | Cats
Xbox cabelas dangerous hunt is there suppose to be
yes there is. it holds all of your memory and a lot more
Mar 13, 2011 | Activision Cabela's Dangerous Hunts 2011
I just purchased a savage .17 HMR with a cabelas pine ridge 3x9x40 tactical scope and I'm having problems siteing it in. It is shooting aout 4 inches low regadless of adjustments I try and make.
A quick and easy way to bore sight your rifle, if it is bolt action only, or an AR, mount the rifle in a cardboard box with cutouts so it will sit without tipping, remove the bolt and sight down the bore at a target 100 yards away, a mail box, or the corner of a building, make sure the rifle doesn't move, then peek through the scope, it should be seeing the same target your bore is seeing, if not, adjust your scope to it, if it won't travel that far, shim the front with pieces of 35 mm film. then check it again, if you can get it to stay there, it will put your bullet on paper at 100 yards.
Mar 07, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
The car is leaking oil and the mechanic said it was because there is a whole in the oil pan and it will cost 1800 to fix. can i buy another oil pan and put it on myself?
OIL PAN
REMOVAL
Drain engine oil.
Remove front engine mount bracket.
Remove power-train bending strut.
Remove structural collar from oil pan to trans-axle Structural Collar - Removal and Installation
Remove trans-axle lower dust cover.
If equipped with air conditioning, remove oil filter and adapter.
Remove oil pan.
Clean oil pan and all gasket surfaces.
INSTALLATION
Apply Mopar® Silicone Rubber Adhesive Sealant or equivalent at the oil pump to engine block parting line Oil Pan Sealing
Install a new oil pan gasket to pan.
Install pan and tighten screws to 12 N·m (105 in. lbs.)
Install oil filter and adapter.
Install trans-axle lower dust cover.
Install power-train bending strut.
Install front engine mount and bracket
CAUTION: The torque procedure for the structural collar must be followed, as damage to oil pan or collar could occur.
Install the structural collar Structural Collar - Removal and Installation using the following 3 step torque sequence:
Step 1: Install the collar to oil pan bolts and tighten to 3 N·m (30 in. lbs.)
Step 2: Install collar to trans-axle bolts and tighten to 108 N·m (80 ft. lbs.)
Step 3: Final torque the collar to oil pan bolts to 54 N·m (40 ft. lbs.)
Fill engine crankcase with proper oil to correct level.
Auto Zone carries the Oil pan you need for around $75.00 and they will have the step by step instructions for you to replace the oil pan. will take just over 2 hours for the average person. Good luck and keep me posted.
Nov 30, 2009 | 2002 Dodge Neon
Just purchased mossberg 935 used gun from cabelas and was told it should shoot 2 3/4 inch shells with no problem,took it hunting shot 2 3/4 bb and T loads and it will not eject, is there something that I...
Hows it goin-
From what I understand, the 935 is a Magnum gun. Therefore it will have some ejection problems with the lighter loads. Ive also been told by multiple people (I am a Firearms Outfitter at Cabelas, Idaho) that the 930 and the 935 are prone to jam... a lot. Personal experience, none....but I talk to a lot of die hard gun users daily.
Also known to be problematic on this firearm are some of the plastic parts on the 935 breaking, namely the forearm retainer and or the pusher assembly. Someone else is bound to speak up here, but I would think your best bet is to jump up to some 3in shells. Hope it works out for you.
Check out Cabelas Website in the "Chat Forum" section. There are some good discussions about your firearm.
LINK TO SITE
Oct 17, 2009 | Mossberg Sport & Outdoor - Others
Pets - Others Logo
500 people viewed this question
Top Pets - Others Experts
Tom Chichester
Ruth summersides
Kardoc
Are you a Pets - Other Expert? Answer questions, earn points and help others
