SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
SOURCE: maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
SOURCE: my tomtom led light comes on when on charge, but
OK I had the same problem, replaced the battery but it still did the same thing, i.e. light came on as if charging but no power to device. Turned out in the end it was a dry joint, to fix remove the case and use a hair-dryer on hot for a couple of minutes on the area on the pcb where the dock connectors join the pcb.
SOURCE: Maytag mjd 2005 when started on normal gives a
I have the same problem but now on all cycles - to get it off normal and try the other ones, open the door, hold down the 'normal' button for three seconds, and then at least try the other settings temporarily.
SOURCE: I just replaced the water
Hi, there is a micro-switch at the filter which shuts off the supply and operation while the filter is out of the unit. That switch is still open, so the dispenser thinks you are still replacing the filter. Try taking the filter out and putting it back in. Make sure any locking mechanism is fully engaged. In the meantime, I will see if I can find the service manual for your unit.
