SOURCE: download music
go to www.limewire.com and download Limewire, its a file sharing application that is very good for searching and downloading MP3s. Download Java Runtime Environment (required for Limewire) go to http://www.java.com/en/download/manual.jsp and choose Windows (Offline Installation) to download. install Java Runtime Environment 1st then Limewire. run Limewire, connect and search audio files.
SOURCE: SanDisk Sansa Clip
Alright, have you located you music yet ?
I personally dont use rhapsody, i use Ares which has worked great for me.
If you have located your music, simply open My Computer, look for sansa, open this and drag all your songs into music.
Well that's all I got.
[djnick your not helping at all, your literacy level is probably the worst on fixya and stop talking about iPods, the focus here is to help Rebel, not advise him to buy other mp3 players]
SOURCE: Lost manual Bernina Sport 108 -need to oil .But where?
Its ok to put a drop or two of oil on any two metal parts that move togeather. Metal gears get grease only and plastic or nylon gears need none at all. Carefull not to over oil as too much will just collect dirt and lint that could cause worse issues.
SOURCE: unable to download itunes from itunes library to sandisk clip mp3
Make sure the files are in MP3 or WMA file format. If they are in a different file format other than the ones above convert them because for audio those two are the file format that the sansa clip supports. Im not sure but iTunes convert songs to AAC or MP4 depending on the settings of it.
The best way to transfer songs tot he sansa clip is to change the mode of the player to MSC by going to Settings and then USB Mode. This would help detect the drive as a flash drive so you could copy and paste songs to it.
SOURCE: Can't download music from Napster to YH-920
I have those too and the Napster thing is annoying, but you can use it or realplayer to transfer music you already own to the Samsung. We upload our CDs in mp3 format and then transfer them. If you buy from Napster, you have to keep subscribing to 'keep' them. But you should be able to upload music you already own, through realplayer or napster. Don't just use Windows Epxlorer to move files over, that doesn't work. (You can store files on the Samsung's hard drive that way, as an archive, but you can't play them.)
