Question about Hyundai Car Audio & Video
We have a 2002 Hyundai Santa Fe sifter locked in Park.The council does not have that little button that you can go in with a screwdriver and try to unlock it. What is our next step here.??
We were viewing a U tube demo our council has no button.!!??
Posted by Susan Koutsios on
5 Related Answers
Anonymous
  • 53 Answers
SOURCE: Drivers Power door lock?
the most common fix for this is what is called the accuator that must be replace it is part of the latch assembely
Posted on Oct 19, 2008
goalie39
Ed
  • 479 Answers
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
Posted on Apr 21, 2009
Anonymous
  • 3 Answers
SOURCE: can't find the shift lock override button on 02 Santa Fe
is the steering wheel lock in place if so thats y you need to turn the wheel left or right to free it up
Posted on May 06, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: PROGRAM KEYFOB FOR HYUNDAI SANTA FE
This is from the factory service manual of your car:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Translation you need the dealer to do this.
Posted on May 22, 2009
ghost4548
Paul McGrath
  • 776 Answers
SOURCE: hyundai santa fe 2002 remote key fob locking ok but fails to unlock. suspect micro switch faulty. can it be replaced?
Do the doors lock normally when using the manual switch on the dirver's door panel? If so, the problem is in the ETACS module. Here's the wiring diagram:
Posted on May 28, 2009
2002 Hyundai Santa Fe won't shift out of park
If holding the brake on does not release the shift interlock,you may have a bad brake switch or shift interlock solenoid.If you can get access to the shift solenoid (usually at the base of the shifter) you can just tie it in the off position if needed.
Mar 25, 2018 | 2002 Hyundai Santa Fe
I have a 2002 hyundai Santa fe and when I turn headlights on the insturment panel don't light up so I can't see how fast I'm going..the cover to the fuses is missing so I don't know what fuse
The dash lights work with the park lights. If the park lights are operational, there is no fuse issue. Make sure the dashlight dimmer control switch is not turned to the low/off position
Jun 13, 2015 | 2002 Hyundai Santa Fe
2001 hyundai santa fe starts with one crank but won't go into drive or reverse, only goes into park and neutural what could be the problem? i have a 2001 hyundai santa fe 2.7 l v6 all wheel drive
You do have drive and reverse,if you have park and neutral.It just the transmission cant transfer that power a new or rebuilt is the solution
Mar 20, 2012 | 2001 Hyundai Santa Fe
My 2002 2.0td hyundai santa fe just stop on me i lost all power i have removed the panel on the left hand side to see the timing belt im woundering is there two belts?
Hello! I need a little clarification...The trouble report list the model as a Santa Fe with a 2.0 td...The Santa Fe does not have a 2.0L engine...It has a 2.4L (4 cylinder) or a 2.7L (6 cylinder)...Please tell me which engine is in the Santa Fe...
Guru.Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 11, 2011 | 2002 Hyundai Santa Fe
Where is the valet button in santa fe 2004
There is NO valet button on the 2002 Santa Fe
Jan 05, 2011 | 2002 Hyundai Santa Fe
My 2002 ZX2 Automatic's sifter doesn't want to shift out of park. Once I get it out of park it drives fine. Any suggestions?
The park lock-out solenoid is bad. It locks the shifter in park until you depress the brake pedal. You can remove the console and replace this solenoid or defeat it with a zip-tie.
Jan 04, 2010 | 2002 Ford ZX2
Can't find the shift lock override button on 02 Santa Fe
Apr 28, 2009 | 2002 Hyundai Santa Fe
Car Audio & Video Logo
Top Hyundai Car Audio & Video Experts
Marvin
Marvin
Jude24
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
