TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
SOURCE: Program my time warner remote ur5u-8780L-TWC to emerson tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
