Question about Archos Audio Players & Recorders
Archos 504 recovery code 2 system is damaged. would like to recovery it?
Posted by rajaram t on
5 Related Answers
Faraz
SOURCE: Archos 504 RESET button
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
Posted on Feb 09, 2008
Anonymous
  • 4 Answers
SOURCE: Archos 604 Wifi Recovery Code 2
hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
Posted on Apr 18, 2008
Anonymous
SOURCE: archos 404 recovery code 2
i have an archos 404 the problem is that my archos show me the recovery code 4 to repair or format the disk so when ever i repair and format the disk the problem is solved. so please help me regarding this.
Posted on Oct 23, 2008
zalmay
  • 6 Answers
SOURCE: can't get out of recovery code 2 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!)
c. connect 504 to pc and wait until pc recognise it (it will recognize it this time)
d. copy firmware from pc and paste it to 504 root directory.
e. press done on 504. now when the device restarts you just select Repair and that should work. :)
Posted on Nov 08, 2008
nickyj44245
SOURCE: Archos 504 160gb wont start
Take the battery off, and to the left of the battery connetion tabs is a small gold button, push and hold for 10 seconds. It should start up after doing this.
Posted on Dec 03, 2008
Recovery code 2 / system is damaged. would you like to recover it ? No Repair Format Disk Any body have any ideas ?
hey, did you sort this out? If so, how?cause I have the exact same problem...If I manage to be fast enough to press the button to "recover" or "format" before the screen freezes then it just goes into recovery for ages but accomplishes nothing. My computer doesn't recognize my archos so oI can't upload anything or update anything.?????
Jul 11, 2011 | Archos 504 500870 Digital Media Player
ARCHOS 504
Did you try flashing the firmware on the unit?
Mar 27, 2008 | Archos 504 500870 Digital Media Player
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
Archos Recovery (code 2)
Send them back to Archos if they are still under warranty. If not, you're out of luck because they'll charge you about US$140 to repair the hard drive + postage.
Sep 10, 2008 | Archos 604 WiFi Digital Media Player
504 recovery screen
hold the tv button slightly earlier than holding the power button, first tv then power (while still pressing the tv button). it should first boot up to a normal green ARCHOS screen, then it will enter the recovery mode.
Sep 08, 2008 | Archos 504 500870 Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
Can't get out of recovery code 2 on archos 504
Dec 13, 2007 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Recovery (code 2)
open the battery pack, and push the hard drive back into it's slot.
it has prongs that attach, tat was always my problem.
sorry if it no help to some.
Sep 29, 2007 | Archos 504 500870 Digital Media Player
134 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
