Question about Vtech Toys
Hello, How do I reset a Vtech MobiGo Touch System please?
Posted by Sarah Throop on
5 Related Answers
Crapu Ser
  • 11 Answers
SOURCE: vtech Mobigo screen cracked can it be repaired?
If this device is still working however the crack is small or not deep enough to affect the picture quality of the device, buy a cheap glass repair kit. This will not only fill the crack but ensure the glass stays protected and will look new. Also, after using the repair kit, be sure to use a anti-glare shied to further protect the screen.
If the screen is cracked to a point where the image is blurred, distorted or the colours are not accuratly displayed, unfortunately the glass will not be able to fix without speacialty parts specific to that device. If this is the case, I suggest you visit the site provided at the bottom and follow the steps indicated on the page.
Glass repair kit and demo:
http://www.youtube.com/watch?v=1FwIC7-bttk
http://www.amazon.com/Fix-Flat-Windshield-Do-Yourself/dp/B000EA5WLS
Replacement Parts:
http://www.vtechkids.com/support_replacement.cfm
Hope this helps. Good Luck!
Posted on Mar 14, 2011
Zarkryn
  • 4 Answers
SOURCE: I have a vtech mobiGo
had the same prob with my son. the games are fun the wife and i couldn't help it.
1. take out the batteries then hold the "on" button for 45 sec replace batteries
2. go to your vtech mobigo acct edit your childs name to "family" or something
3. now add the child you wanted to "reset" now switch mobigo from "family" to new child
4. plug mobigo into pc and the progress log should be reset
thats what worked for me hope this helps
Posted on May 09, 2011
Jesse Bush
  • 10 Answers
SOURCE: Any way to save a
Hi cheshirecat5,
A good way to save any electronics (not 100% guarenteed) is to take apart as much of the device as you ar safe with (unscrew the main plastic at least) and place all the parts in a bowl a white rice, make sure that the entire device is under the rice. Keep it this way for about 24 hours and then reassemble your Mobigo.
Cheers,
Jesse
Posted on Aug 08, 2011
gar2529
gar2529
  • 3 Answers
SOURCE: my vtech mobigo speakers are not working only
Mobigo uses a small cheap speaker. Inside the speaker the glue comes out and the speaker fails
I can fix this for you or tell you how to quick fix it to about 85% of normal.
First, make sure you have good batteries. Then, plug in headphones. If you can hear it in the headphones then your issue may be the common speaker issue.
1 - If you are mechanically inclined then email me [email protected] and i will tell you how to fix for free
2 - I will fix it for $10 labor. you pay shipping (about $14)
3 - I can install a new speaker for $20 more (that is the cost of a new speaker)
Hope this helps!
Posted on Dec 17, 2012
Hal Ames
  • 104 Answers
SOURCE: How can I dry out a mobigo vtech kids game
The best way to dry out any electronics is to submerge it in rice for 24 hours.
Posted on Jan 17, 2015
I have a mobigo 2, which upon turning on tries to update the firmware, then prompts me to connect it to the computer. I downloaded the learning lodge yesterday, and connected the mobigo 2. The softw
register the toy to your Learning Lodge account. upon connecting the toy to yoir computer turn it on. LL should open. click the picture of the mobigo 2. u'll be taken to another page wherein you might see an option to update for firmware or where you will get a prompt that an update is available. if that doesnt work then you need to call the vtech hotline
Feb 16, 2015 | Vtech MobiGo 2 Touch Learning System -...
Vtech mobigo 2 the screen keeps flashing it wont even turn off will not respond to nothing
try this: take the cartridge from both compartments. take out the cartridge. press the on button for 30 seconds. place the batteries back into the toy. try turning it on.
May 09, 2014 | Vtech MobiGo 2 Touch Learning System -...
Mobigo 2 wont load just shuts off
the only answer is that somebody used them that the only answer
Mar 23, 2014 | Vtech MobiGo 2 Touch Learning System
SYSTEM PROBLEM FOUND
You need to update the toy. Connect it to your Learning Lodge Navigator. You should be prompted for an update.
Aug 03, 2013 | Vtech MobiGo 2 Touch Learning System -...
Vtech mobigo 2 need to connect to computer got wet
Toy is probably already defective if it got wet. Sorry.
Apr 20, 2013 | Vtech MobiGo 2 Touch Learning System -...
Mobigo 2 cartridges won't play
My son's is doing the same thing just emailed vtech as well
Jan 25, 2013 | Vtech MobiGo Touch Learning System - Blue
I can not get my mobigo to work
MobiGo headphone jack has a microswitch that shuts the mini-speaker when you insert the headset jack. This microswitch somehow short-circuits the mini-speaker and burns it. Then, if you try a new speaker, it does not work. What you should do is find an electrician, ask him to change your mini-speaker with another one, fit it and then BRIDGE the microswitch and voila. Your MobiGo mini-speaker will work fine.
This is of course something that the genius design and electrical engineers of VTech could never possibly do for all us because of the EXTREMELY high costs and science involved in changing a lousy speaker and a microswitch.
BMW PARTS
May 25, 2012 | Vtech MobiGo Touch Learning System - Blue
Hi my mobigo has said that i have one a prize how do i collect it
Hi.
You need to connect the Mobigo to a computer with internet connection On. Use an USB cable, the Mobigo will download the reward. Alternatively contact the manufacturer: http://www.vtechuk.com/about-vtech/contact-us/
Apr 05, 2011 | Vtech Mobigo Learning System
I have a vtech mobiGo touch. I want to reset it. Start fresh. I just learned about the progress log an want to watch him grow an learn. An everyone in the house has played it so i cant tell what he has...
Mar 11, 2011 | Vtech Mobigo Learning System
I'd like to know how to reset my daughter's mobigo so that it will be able to trace her accoplishments. Currently her, aunt, mother and myself performed multiple tasks for her, and I want to erase the...
Feb 26, 2011 | Vtech Mobigo Learning System
Toys Logo
608 people viewed this question
Top Vtech Toys Experts
ThaMp3Doctor
ThaMp3Doctor
Geoff
Anthony Ward
Anthony Ward
Are you a Vtech Toy Expert? Answer questions, earn points and help others
