Question about Acqua Watches
Lost my Acqua Indiglo Digital wristwatch User's Manual...how can I get another?
Posted by Howard Levita on
Geoff
    Dedicated:
    Visited the website for 20 consecutive days.
  • 125 Answers
Acqua watches are made by Timex. For a manual for any model, go to https://www.timex.com/watch-manuals.html
and choose your watch.
Posted on Oct 17, 2017
5 Related Answers
Anonymous
SOURCE: Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Posted on Feb 14, 2008
Gerald Reiner
  • 23 Answers
SOURCE: Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
Posted on Oct 02, 2008
Anonymous
SOURCE: Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Posted on Nov 04, 2008
Anonymous
SOURCE: Acqua Indiglo watch
all u have to do is hold the split/reset button and then push the mode button it should work
Posted on Nov 25, 2008
Anonymous
Can't understand instructions
Posted on Aug 31, 2009
I received a used Acqua Indiglo watch recently which appears to work but I have know idea how to set the functions. How can I attain a manual? Thank you
This web page explains how to set the watch:
http://wiki.answers.com/Q/How_do_you_set_time_on_a_acqua_indiglo_30m_watch
Also, if you google "Acqua Indiglo manual" you will find many other articles that explain how, in case that one doesn't work (but it should).
Hope this helps.
Dec 15, 2010 | Watches
I NEED THE INSTRUCTIONS MANUAL FOR AN ACQUA INDIGLO MEN'S WATCH. hOW CAN i FIND IT?
mcdevito75 here, You can visit Acqua Indiglo.com or check with a small watch repair shop in your area.
Jun 28, 2010 | Bulova Watch
How do i change the time on my vestal crusader watch?
How do I change the time on my Acqua Indiglo watch? I lost my instructions.
Mar 15, 2010 | Columbia All Sport Digital watch
I need an instruction manual for an Acqua Indiglo digital mans watch. There is no model number on this watch. It has 1 button on each side of the case that are caddy corner from each other. On the front it...
Go to Timex.com and see "manuals" at the bottom of the screen. You can download the manual for the acqua and expedition series of watches.
Thanks!
Sep 22, 2009 | Watches
Can't set time in acqua indiglo w-19 watch
http://www.timex.com/gp/node/n/255235011/178-1795200-7359408?ie=UTF8&timexBrand=core
This link will take you to the official Timex page where you can download the instruction manuals for any of their watches.
This will have the specific instructions on how to set the time.
Jan 13, 2009 | Timex Ironman Triathlon 51931 wristwatch
Need instructions to set ime on INDIGLO watch
David, Try www.timex.co.uk/manuals.aspx then select your watch
(if this helps you please rate)
Dec 10, 2008 | Timex 27191 Wristwatch
Acqua Indiglo watch
Nov 04, 2008 | Timex Ironman Triathlon 51931 wristwatch
Acqua Indiglo watch
Aug 31, 2008 | Watches
INDIGLO watch setting procedure
how to set the time from military to reg
May 04, 2008 | Timex 27191 Wristwatch
Watches Logo
142 people viewed this question
Top Acqua Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you an Acqua Watch Expert? Answer questions, earn points and help others
