Refrigerators Logo
Jack Riggins Posted on Oct 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
,Whirlpool refrigerator WRT311FZDM. Frost in freezer, especially in & around the ice maker. Also a small amount of. moisture on the lower left corner of the freezer on the hinge side.
Chris Huff
Level 3:
Top Expert:
  • Master 6,289 Answers
  • Posted on Oct 14, 2017
Chris Huff
Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020296
Points
74913
Sounds like a bad door seal or dispenser door is not closing properly
1helpful
I'm getting the error code 1F and it keeps coming back. The water line to the icemaker is disconnected and has been. How can i keep it from coming back?
The error code 1F on an LG refrigerator indicates a problem with the ice maker fan. The most common cause of this error code is frost or ice buildup around the fan. If you have disconnected the water line to the ice maker, then the most likely cause of the error code is frost or ice buildup. To fix the error code 1F, you will need to defrost the ice maker fan. This can be done by following these steps: Unplug the refrigerator or turn off the circuit breaker that powers the refrigerator. Remove all food and drawers from the freezer compartment. Open the freezer door and allow the ice to melt. Once the ice has melted, use a hair dryer or heat gun to melt any remaining frost or ice around the ice maker fan. Wipe away any moisture with a clean cloth. Reassemble the freezer compartment and plug in the refrigerator or turn on the circuit breaker. If the error code 1F persists after defrosting the ice maker fan, then there may be a problem with the ice maker fan motor or the control board. In this case, it is best to contact a qualified technician for assistance. Here are some tips to prevent the error code 1F from coming back: Keep the freezer door closed as much as possible to minimize air circulation. Defrost the refrigerator regularly, even if the ice maker is not in use. Clean the ice maker coils regularly to prevent frost buildup. If you live in an area with hard water, consider using a water softener to reduce the amount of minerals in the water that can contribute to frost buildup. By following these tips, you can help to prevent the error code 1F from coming back and keep your refrigerator ice maker working properly.
2answers
Whirlpool refrigerator--water freezing in floor of bottom freezer then leaking onto floor
whirlpool bottom freezers with ice forming on the freezer floor is nothing new. It is formed most likely by an ongoing issue with the design of the defrost drain becoming clogged and there is a revised kit for it part# W10619951.
Whirlpool has extended the warranty of this issue only to two years from the date of purchase and will usually give you the part but charge for install.
It can be put in in less then 10minutes using just a 1/4" hex bit and a small flat blade screwdriver to release the clip on the old "slide" style drain.
Once installed,it is best to defrost the fridge for at least 24 hours (doors open and unplugged) to make sure all ice is melted from inside the unit.
If your drawer was not closing,you would have frost.. If your defrost timer (which virtually no newer units have since digital controls are the norm with adaptive defrost) then you would have frost,not ice.
The fact that you have water is telling me it is defrosting and re freezing.
List a model# for further support if needed please
I've got a small leak in my refrigerator. I thought it may have been overspray from the ice maker but we still get water in the refrigerator when the ice maker is off.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Freezer is starting to frost up, what could the issue be? how can i determine and fix?
1 Could be a bad door seal letting moisture in.try cleaning the seal and area around it.
2 Bad defrost timer.self defrosting only.
3 Setting is too cold.
4 Clean out condenser,unplug fridge.condenser is in the back lower part of fridge.May also be located on the back of fridge.
5 Low on freon.
Freezer compartment of my fridge ices up quickly
Check seals around door....you need to reduce the amount of moisture entering the freezer compartment.
The frost will build up on anything in there.
3helpful
2answers
Bottom of ice maker is frosted up & leads to food getting frost
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
3helpful
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Kenmore Bottom Freezer Ice maker installation
in the bottom style freezer the plug will be in the upper left hand corner of back of the freezer ,,, may have a cover plate over it but thats where it is and should be a couple small holes with plugs on the upper left hand side for the mounting screws / larry
1helpful
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Top Frost Refrigerators Experts
vince
john h
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
