Need a code for a hyundai television serial number 6011604481
HYUNDAI HU-TV2121 processor N403 KALORA HHEN16MD01.Videoprotsesor
LA76810A - the very bottom hidden button (right of the circuit), click
once highlighted FACTORY. More P + and P-switching options.
HYUNDAI C2910, C2519, C2988
1. Set the volume -0
2. Press the remote button "MUTE"
3. While holding "MUTE", press "MENU" on the front of the TV.
4. On the top right corner will light up the letter "D", and in the left
corner shows an adjustable parameter and its value.
5. Pages menu change button "CAL"
Switching parameters conducted green and red buttons on a blue field
panel. Change made a yellow and blue buttons on a blue field.
HYUNDAI H-LCD2000
To enter service mode simultaneously press "MENU" and "STANDBY".
Press "MENU" again.
HYUNDAI, ITT 29M03 C2131 chassis CPU M37160M8-064FP
In the main menu code 6, 4, 8, 3.
Tools submenu contains the switch to the next of which is done by putting 6, 4, 8, 3.
HYUNDAI 359, 387, 8FHIFI, CB5373Z, 6578F processor CCU SEL04 / SEL07A
Mode 1: Close contact in the hole near the keyboard and just press "S"
Mode 2: Close contact in the hole near the keyboard and just press "S" again and click on contact. Exodus - LOAD.
HYUNDAI processor SAA1293-03-03 SAA1293A
With remote control TV "Horizon" graphics without clicking "SERVICE",
the indicator shows a CH, a paz-click on 'appears OP, then choose the
volume of registers numbers "1-4" and numbers "1-9" change bits. Then
click on "Memory" (you can also lock the pins 15 and 23 in the control
circuit SAA1250). Exodus - POWER OFF.
HYUNDAI chassis CCU11 - "•?" (C) (H)
Chassis CCU12 - close contact in the hole near the keyboard and just press "S". Exodus - LOAD.
HYUNDAI chassis M1, ITT, NOKIA, SALORA 6390, 7190, MV4000, PL14
24 101 852 SAT SOLI, 882 SAT SOLI, 885 SAT SOLI processor CCU-SALO-07
(CCU20XX)
entrance "C"> "*"> "O / V"> "#"> "M". Exodus - "power".
HYUNDAI chassis EUROSTEREO-1. DIGIVISION 1963 .. 2, 1971 .. 2, 2 .. N6 processor NES3-... NES2-..
Log "-/--" "MENU" "TV" - for a second. Exodus - POWER OFF.
HYUNDAI chassis STEREO PLUS. 5575SFN, 28T7 processor ST92T93
Entrance - "i" "M" "P +", output - TV.
HYUNDAI 3875EX DIGIVISION
Gun "AV7 universal" fully fit.
Sign in service "1-/11. (Button with painted upper corner). TV must be turned on and display a feed.
Recommended initial value: V.AMP-027. V.LIN-038. S.COR-020. V.POS-023.
H.POS-041.H.AMP-022. P.TILT-013. P.AMP-024. P.CORN-007. GREEN-032.
RED-032. BLUE-032. V.BRE-005. LUM.DEL-000. AUDIO-032.OPBYT1-002.
OPBYT2-064. OPBYT3-000. PRLOSK-000. RESERVE-000. Writing in memory -
click "E".
Memory 24c08 can put a clean, turn on TV it propyshe processor itself.
from electronics-planet .blogspot
