Question about Lazy Boy La Z Boy Harmony Lounge Sleeper Chair HA2800
Can I buy parts to fix my lay z boy ?
I have a lay z boy wall away couch recliner on each side It was purchased in 1999 or 2000 hardly used but I have found what looks like a plastic roller cover under it. Just one side but it started squeaks just a little . can those parts be purchased.
glenn Meek
    Habit-Forming:
    New Friend:
  • 34 Answers
Try https://www.la-z-boy.com/content/CustomerCare
Posted on Oct 13, 2017
5 Related Answers
John Jon
  • 1114 Answers
SOURCE: door handle 1996 thunderbird
sounds like a plastic Sir clip of course you say external handel detached from door consider linkage clip has fallen down!
Posted on Dec 23, 2008
Anonymous
SOURCE: replace rear turn signal bulb on 2007 H3 - driver side
1st::Unscrew the 2 screws that hold the light in.
2nd::Slide your hand behind the light and pull the light towards you. Make sure that you pull it straight, as if the h3 was driving away from you, so you dont break the two pins that are holding the light in...PULL ONE PIN AT A TIME!!!
Dont pull it to far away from the hummer as there are wires attached that need to stay attached.
3rd::turn the back of the bulb to unlock it from the lens...
4th:: slide the bulb out and remove thebulb by pulling it straight out.
5th::put the new bulb in, lock it back into the lens, then insert it back where you got it from,...
MAKE SURE you move the wires out of the way when you put the lens back in...they will get in the way and can be damaged.
Posted on Apr 07, 2009
Anonymous
  • 37 Answers
SOURCE: Camaro - broken reclining seat mechanism
the recliner is the outside seat hinge and has 4 bolts holding it to the seat cushion and seat back.The seat covers need to be pulled back to gain access to bolts.Can be done with seat in the vehicle.
Posted on May 27, 2009
Anonymous
  • 202 Answers
SOURCE: 1994 Cadillac Deville front seat recliner broken
Not a very common problem. You can get either the part from the dealer, or the seat from the junk yard. It will have the piece you need to correct the issue.
Anonymous
  • 7 Answers
SOURCE: lost cover for right side mirror. black color.
I would go strait to the dealer for this part.It will cost you a few more dollars than some online store but it will be an exact fit the first time and retain the value of the vehichle by replacing the missing part with a OEM part.
Posted on Jul 12, 2009
How to operate lazy boy recliner how to recline it
simply lay back in it to push the back rest backwards
Jun 15, 2016 | Furniture
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
The metal bar locking mechanism on my reclining sofa broke. Its a metal frame. Can the broken metal piece be welded?
Depends on the metal because not all metals are the same. There are some that if you try to weld them they just vaporize the instant heat touches them. The only way to know for sure is trial and error. Take that whole assembly off the couch before you try welding it. If you try to weld it on the couch, you'll set the whole couch on fire. You might just want to call the couch manufacturer and see if you can order a replacement. Or take the part to the place you purchased it from to see if they have had any experience with success of getting replacement parts. Most likely they'll say no but be happy to sell you another couch. I would say try welding it; if it works great, if it doesn't you can put it back on and lock it in position and still use the couch, but without the recline.
Mar 30, 2015 | Cars & Trucks
How do I get assembly instructions for Wildon Home Corvallis Trimline Full Size Futon Frame?
You can contact factory direct or place you purchased from. Contact Us: 877-WAYFAIR (877-929-3247). I know the item is from Vietnam and instructions are not the best.i would lay out all your screws by size. Connect your back board to both end pieces withe the medium size screws. Then mount front board with long screws should be 4 for each side. Then assemble the couch lay down parts place on your assembled base. Uses washers on the long screws as this section swivels up and down. This reduces friction between the wooden parts. I hope this helps. Send your photos to mddoc13atyahhoodotcom. I will try to quite you. Attention Bob
Feb 01, 2015 | Wildon Home Corvallis Trimline Futon Frame...
Rollers on lazyboy reclina rocker
Lazy Boy recliners usually have a lifetime warranty but I beleive that it is for only the parts not the labor. I had the same problem and went to the dealer asking the same question. They gave me a number to call to have the parts shipped to me. We ended up buying a new couch instead for other reasons so I never tried calling the number. You should call your local retailer and get the number and see what they will charge you to install them for you if you can do it yourself.
Mar 25, 2014 | Cars & Trucks
Power seat -drivers side
What ever it is you can't buy the parts anymore.
Mar 14, 2014 | Saturn Cars & Trucks
Lazy boy recliner with heater an d massage: I
Sorry we do not have any wiring diagrams for this chair here.
Apr 14, 2017 | Coaster 500663 Tri-tone Lazy Boy Style...
Recliner foot rest bolt broke and spring came off
looking for two small springs that go in the foot lift section of a lazy boy recliner. these springs allow you to raise the foot lift to different positions. these are very small springs and attach to each side of two small drum types.
Mar 22, 2013 | Lazy Boy La-Z-Boy Power Lift Recliner...
May 27, 2009 | 1994 Cadillac DeVille
Lazy Boy La Z Boy Harmony Lounge Sleeper Chair HA2800 Logo
1,869 people viewed this question
Top Lazy Boy Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Lazy Boy Furniture Expert? Answer questions, earn points and help others
