Computers & Internet Logo
C
Constantino Pena Posted on Oct 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cyberlink Power Director 14. Burning Unsuccessful. Error eFF030C00
I capture and edit my home made videos using Power Director 14, but I am unable to burn it on a DVD. I get the above error. I use DVD-R discs with a cpacity of 120 minutes. Please help.
tosin_christ
Level 2:
Sergeant:
  • Expert 242 Answers
  • Posted on Oct 13, 2017
tosin_christ
Expert
Level 2:
Sergeant:
Answers
242
Questions
0
Helped
45223
Points
822
DVD-R disc probably defective. Source for another make of DVD-R disc and try again.
DVD capacity matters; how many Gigabytes of data can it take/record/accommodate
4Gb
8Gb
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Feb 01, 2007
SOURCE: can not burn cd or dvd on on double layer burner
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check ENABLE cd recording on this drive driver - update or uninstall reboot your computer 3. go to support.toshiba.com look for the EXACT model of your toshiba notebook a) download latest BIOS b) download the cd driver Goodluck!
Anonymous
  • Posted on Mar 09, 2009
SOURCE: Failed to burn DV disc.Cyberlink Media Show error code 0x0A180001
I was also suffering this problem with Nero 6. To solve your Problem first make sure that the windows you are using that supports your Software if supports, then your Optical Drive may not Write in high speed 16x or 18x, write your files in DVD in little bit slow speed, after doing all this if it gives same problem then Please reinstall your windows you are using.
Anonymous
  • 432 Answers
  • Posted on Apr 10, 2009
SOURCE: Cyberlink DVD Error 80040216 error code
I would un install it and re install it and try again also trying VLC or windows media player classic
also see here http://www.rm.com/Support/TechnicalArticle.asp?cref=TEC1415974&nav=0&referrer=SupportHome
Anonymous
  • Posted on Aug 06, 2009
SOURCE: Unable to burn vidio onto DVD_error code FF037303
hey i have also had the same problem, but mine was as simple as dodgy dvd's. i bought about 25 in bulk and that same code ff037303 came up with about 10 of them. even when i tried to create dvd in another program it got to 98% then stopped. go and buy new dvds and try again. great camcorder though.
AnwarH
Anwarul Haque
  • 107 Answers
  • Posted on Mar 29, 2010
SOURCE: unable to burn dvd, unable to access the video_ts.ifo
which software are u using ?
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
2answers
I'm trying to capture video from my new Kodak zi8 camcorder and power director says "disc does not contain any content supported by Cyberlink Power Director". What do I need to change?
Hi ,
You need to convert the original files to Mpeg files . If they are MOD files , you can do this by using a specific tool designed for it : SDCopy , you can download from here :
http://www.mediafire.com/?wzmigzhjj0z
If your orinal files are others than MOD , you need to identify them first but conversion to MPEG is the secret .
Good luck !
1helpful
How to Turn a Regular Video Camcorder Into a Webcam
Hi, maybe you can try to download a software like Cyberlink Power Director 8. After installing that software, you can connect your Camcorder to your computer then Open the Power director you have installed and go to the "Capture" tab and see for your self.
Hope this helps you..Merry Christmas ( :
2answers
Burning of DVD from Power Director V7
LOOK IN TOOLS AND SETTINGS OR HELP AND FIND THE UPDATE BUTTON AND UPDATE THE SOFTWARE. PLUS YOU ARE RIGHT THAT IT MAY BE PROBLEM USING EXTERNAL DRIVE.(IS IT USB 1.0?)..COPY YOUR FILE TO A TEMPORARY FOLDER ON YOUR DESKTOP AND BROWSE TO THAT FOLDER WITH POWER DIRECTOR.
Dazzle DVC 90 does not work in Vista
Hi there!
Try unplugging the DVC90 and uninstalling it from Device Manager. Then go to the Control Panel and delete all the drivers you find. Reboot and try the installation again. If I remember correctly you can run PCLUSB2.exe first to get the drivers on your hard drive and then plug the device in. When you do that just point the driver install to the folder that the drivers got installed to.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Where can i get freeware/shareware copy of power producer 2 gold from please
Power Producer Gold 2 is not a shareware/freeware program; it's a commercial, off-the-shelf product from CyberLink. It is video-editing software and is used for home moviemakers looking for a user-friendly program. PowerProducer 2 is compatible with many movie formats and can double as a digital photo album. It's generally available at around $69.95. It won't add incredible graphics or Hollywood special effects to your movies but it's a reliable and simple system for capturing video, cleaning it up with editing tools, and burning the end product onto CD or DVD.
I don't know if Power Producer 2 Gold is available becaue Power Producer 5 is on the market. You can get more information on buying it at www.gocyberlink.com
Let me know if this helps.
[email protected]
I believe it's available for about $69 from sold by CyberLink
What editing program do I get with this camera?
The PC Kit provides movie capture, DVD authoring, DVD-R burning, photo editing, and DVD playback capability on PC based computers equipped with Windows 98, ME, 2000 and XP. The kit includes a USB Cable, USB1.1 Driver, UDF2.0 Writer, CyberLink Power DVD XP, Ulead® DVD Movie Factory SE for DVDCAM and Ulead Photo Explorer7 Lite.
Top CyberLink Computers & Internet Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
