Televison & Video Logo
Janie Erickson Posted on Oct 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What causes pictures to go out of sequence? - Televison & Video
JOHN TOPLISS
Level 2:
Habit-Forming:
  • Expert 180 Answers
  • Posted on Oct 13, 2017
JOHN TOPLISS
Expert
Level 2:
Habit-Forming:
Answers
180
Questions
Helped
37455
Points
380
Do you mean the sound is not in sycn if so try a retune
Samsung LN40A550P3FX2A will not power up with picture.
take a hair dryer with back off and heat specific areas unit you find the location that is causing this, either main board or power supply are possible.
Looking for a picture of the bolt sequence for the cylinder head on a 1991 acura 1.8l dohc.
THIS IS BOLT SEQUENCE WRITE THIS DOWN PIECE OF PAPER AT TOP PAPER BOLT SEQUENCE NUMBERS ARE 8 6 2 4 10 THEN WRITE THESE BOLT SEQUENCE NUMBERS UNDER THE TOP NUMBERS 9 3 1 5 7 THIS IS BOLTS SEQUENCE.
Computrt turns on no picture? HP Pavillion a 262
The computer displays logos from the manufacturer during, before programs are loaded onto the screen. Once a program has been selected with movie functionalities, several sequencies of pictures make up movies. A no picture display is indication of malfunction of the computer default causing the user programs tobe displayed.
contact a technical expert
Sharp tube tv 1998. Comes on momentarily, then picture fragments starting at top and bottom at same time. Final indication is a thin bright horizontal line across mid tube, then internal circuit breaker...
The most likely cause of the issues is bad electrolytic capacitors.
Not worth fixing IMO.
Tracking down and replacing the caps would be many hours work...
When i turn on my monitor the green light comes on then goes to yellow ... no picture ,just black. what causes this
This light sequence typically means there is no signal coming from the computer. You can verify by trying the monitor on another computer or trying a different monitor that is known to work on this computer.
1helpful
Photos are out of sequence, summer mixed with winter, one event mixed in all other mixed events.
The camera just assigns names in numerical order (IMG1234, DSC5678, etc.). If you delete pictures or transfer some to your computer and leave gaps in the sequence, the camera will reuse the names. So your photos are out of sequence based on the filenames.
The easiest solution is to not let pictures accumulate in the camera. It's not a safe thing to anyway, since if something happens to the camera or its memory card you will lose all your pictures. When you finish shooting a bunch, upload them to your computer so you can file them. Change the names to something more meaningful than the simple camera-assigned number. Put them into folders so you can find all your trip to the beach photos easily. THEN BACK THEM UP ONTO A CD!!
If you have a whole bunch of pictures in the camera already and they are mixed up, you can upload them to your computer and use the software that came with the camera to organize them by photo date. You can also download applications such as Picasa to do it.
Apr 30, 2009 • Cameras
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
2answers
No picture and a sequence of 5 orange flashes on the power button
gotta unplug it let it reset, let it sit for at least 3 minutes, then plug it back in...but you may need to clean it out remove the bulb grab a rag and a shop vac and clean out the bulb housing. then take off the back along with the left speaker and clean it out (the same way) basically the dust is keeping the heat in and it is causing an overload,.,,
SEQUENCING PICTURES IN BUILT-IN MEMORY
The DPF-80 has now way to sequence pics. The only way for them to play in an order is add them one at a time to the frame via the computer. The files can not be batch sent, such as sending a whole folder at one time. Windows will dictate the order in which they are transfered if you do it that way. Transfer one pic at a time. Tedious, but it works
DMR-EZ485V -- slideshow of JPEG pictures not in correct sequence
Adjust pictures sequence before burning? usually they can be sorted by file name, date photo taken, date modified.
Some slideshow software also allows you to drag pictures to any position in sequence you want, say Wondershare Movie Story I am using.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
