Question about KitchenAid Kitchen Ranges
SOURCE: KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Posted on Jul 04, 2009
SOURCE: "set probe temp" flashing and beeping on kitchenaid wall oven
I plugged in the probe and stuck it into a pyrex measuring cup of water, set the probe temp to 165, set the convection (or bake) oven to 500, and turned it on. This allowed it to run for about 20 minutes, and cleaned out the probe jack. Works fine now.
Posted on Aug 02, 2009
SOURCE: my kitchenaid architect series II gas range is
In most cases, this is an indication that the Electronic Range Control (ERC) is defective and needs to be replaced. The ERC controls all the features of the oven, so without it, you cannot turn the oven on or regulate the temperatures. You can attempt to reset it by unplugging the range for at least 30 seconds, first. Or you can try disconnecting each wire from the ERC and reseating it (one-at-a-time) to ensure you have good connectivity. However, if the problem persists you will need to replace the ERC.
If parts are required, you can purchase on line at the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these websites to be reliable, offer great service and the prices are usually cheaper than retail. The prices will differ between sites, so shop around for the best deals.
If the model number you have this listed under is correct, the part number for the ERC is 9762794. The cheapest website I could find it was on the Sears website for about $158. (Not a cheap part no matter where you look for it).
To replace (if necessary), follow these steps:
1. Make sure the appliance is unplugged.
2. Remove the screws that hold the back of the control panel in place.
3. Take note of the wire color coding BEFORE removing any wires from the ERC. Most control boards will have the colors printed on the board by the terminals. If yours is not listed, either write the wire color codes down or use a digital camera to ensure you note the proper placement of the wires.
4. Remove the wires from the control board and the screws that hold it in place.
NOTE: Most ERC boards do not come with the overlay (This is the plastic that covers the facing of the EOC with all the features on it). Remove the old overlay from the old board if you wish to reuse it and install it to the replacement board.
If you have questions, please let me know. I hope this helps you.
Posted on Sep 23, 2009
SOURCE: Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Posted on Sep 29, 2009
Jan 26, 2015 | KitchenAid Kitchen Ranges
Dec 10, 2012 | KitchenAid KGST307 Gas Kitchen Range
Hi
F2-E1 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 14, 2011 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Hi
Daniel
Aug 31, 2011 | KitchenAid KESC307 Electric Kitchen Range
Apr 27, 2010 | Ovens
Jan 17, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
Jul 13, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Jun 22, 2008 | Kitchen Ranges
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
Nov 22, 2007 | KitchenAid KESC307 Electric Kitchen Range
Jul 03, 2019 | KitchenAid Kitchen Ranges
