Step
Turn off the
TV, and unplug it. Make sure to disconnect it from the outlet completely.
Step
Locate the bulb door of the TV. This is often on the back, near the power cord. Slide the door open and reveal the bulb.
Step
Unscrew the screws. Some screws are thumbscrews, while others may require a screwdriver.
Step
Gently remove the bulb. Pull the bulb out of the compartment, usually
by grasping a handle and then pulling out and slightly down.
Step
5
Install the new bulb. Line up the groove on top of the new bulb's housing with the groove pocket on the inside of the
television. Slide the new one into place.
Step
6
Tighten the screws. Do not overtighten them; they should be finger-tight only.
Step
7
Close the door. Make sure it is closed completely or the TV will not operate.
it depends on if your a handyman
